Author Topic: 66 67 fairlane big shaft top loader  (Read 3049 times)
Jb427
« on: October 10, 2021, 09:56:59 PM »
I need some help I am trying to find what clutch fork i need for a big shaft top loader in a fairlane dose any one make them new?.
Gregwill16
Re: 66 67 fairlane big shaft top loader
« Reply #1 on: October 11, 2021, 05:45:10 AM »
The only big shaft clutch fork reproduced is the Mustang. I am not sure what they had originally, may have been the same fork, but you should be able to make it work.
GerryP
« Reply #2 on: October 11, 2021, 07:03:41 AM »
It seems to be the same fork in function.  That is what I am using (C8OA 7517 D for the factory 428 CJ BI/BO TL) in my '67 Fairlane BI/BO long tail CR toploader.  I don't know what differences there are between that fork and say a factory 427 Fairlane fork, but the Mustang fork works just fine.
« Reply #3 on: October 11, 2021, 07:50:12 AM »
When I was putting my 59 together a few years ago, I bought a new clutch fork from McLeod. I have a small spline Toploader in my 59, so I bought the small input clutch fork, but McLeod showed 3 different forks available, including the big input Mustang unit. Price was very reasonable as well. The fork I got was the later "leaf spring" style, so I bought a new fork pivot fulcrum, with the slot for the spring from McLeod at the same time. I much prefer the later style spring and pivot, over the early wire clip version.
Jb427
« Reply #4 on: October 11, 2021, 07:58:07 AM »
Im not happy with my Hydraulic throwout bearing it works fine just no adjustment for clutch feel so i was going to try a fork and slave cylinder i wont be using the z bar and i don't care about factory part just need parts that will work with the fe in a fairlane with a lakewood scatter shield and big shaft toploader.
fairlaniac
« Reply #5 on: October 11, 2021, 12:09:06 PM »
I do not use the wire clip on fork on my '66 with scattershield. I switched to a '68-later clip type. You can find forks and clutch parts at Branda and Mansfield Mustang.
https://store.cobranda.com/clreit.html
http://mansfieldmustang.com/Transmission.html
Doug Bender
1966 Fairlane 427+/5 Spd TKX
1978 F150 2WD 390
« Reply #6 on: October 13, 2021, 02:15:17 PM »
66 and 67 would have used wire clips, the leaf spring clip was new for 68
