Author Topic: Bullocks Power Service 496 Genesis, Dove SK heads, tunnel wedge, pump gas  (Read 4711 times)
Performance Summary:
      Cubic Inches: 496          Dyno brand:  Stuska
      Power Adder:    N/A
      Where dynoed:  Dale Meers Racing Engines, Buffalo, KY
      Peak Horsepower:  608  @ 5900
      Peak Torque:  612 @ 4750
Engine Specifications:
   Block brand, material, finished bore size, other notes:  Genesis 4.31
   Crankshaft brand, cast or forged, stroke, journal size: SCAT 4.25 stroke, 2.20 journal, cast
   Connecting Rods brand, material, center to center distance, end sizes, bolts:  SCAT H-beam BBC 6.70
   Piston brand, material (caster, hypereutectic or forged), dish/dome volume, static CR: Diamond 1.325 compression height, 22 cc dish, 10.5:1
   Main Bearings, Rod Bearings, Cam Bearings brand and size:  Clevite H rods, King coated mains, Durabond cam bearings
   Piston rings brand, size, other notes: Mahle, 1/16 3/16 standard tension Napier second
   Oil Pump, pickup, and drive:  Melling M57HV, Moroso pickup, POP drive
   Oil pan, windage tray, oil filter adapter:  Moroso deep sump, factory windgae tray, billet oil filter adapter
   Camshaft brand, type (hyd/solid, flat tappet or roller), lift and duration (adv and @.050"):  Custom Bullock's Power Service, Comp sourced,  high vacuum street hyd roller, 242/248 @ .050
   Lifters brand, type:  Morel standard travel
   Timing chain and timing cover: PoP 9 position billet with torrington bearing and factory timing cover
   Cylinder heads brand, material, port and chamber information:  Dove SK, some cleanup and fresh multi-angle
   Flow bench used, location:
   Intake valve brand, head size, stem size: 2.25   11/32
   Exhaust valve brand, head size, stem size:  1.73 11/32
   Valve springs brand, part number, specs:  Comp 930-16 155/400
   Retainers and locks brand, part number, specs:  Comp with Manley seals
   Rocker arm brand, type (adjustable or non-adj), material, ratio:  Lykins non-adjustable 1.76
   Rocker shafts and stands, brand, material:  Precision Oil Pumps
   Pushrods brand, type, length:  Trend, 5/16, .080", various lengths
   Valve covers, brand, type:   Ford Baldy
   Distributor brand, advance curve information:  Factory mechanical dual point, dyno'd with single points triggering 7AL
   Harmonic balancer brand:   Performance Products
   Water pump brand, type (mechanical or electric):   Edelbrock
   Intake manifold brand, material, porting information:  Tunnel Wedge
   Carburetor(s) brand, type:  2x 715 reproduction Holley vac sec, progressive
   Exhaust manifolds or headers brand, type:  Dyno headers, 2" tubes
« Last Edit: March 27, 2023, 03:16:07 PM by My427stang »
Re: 496 inch, Genesis block, Dove SK heads, tunnel wedge, pump gas hyd roller
« Reply #1 on: September 26, 2021, 07:48:22 PM »
Nice Ross I don’t know the lobe or lift numbers but seems like a very conservative cam and it still makes good horsepower.
« Reply #2 on: September 26, 2021, 10:39:30 PM »
There isn't a rule about having to post pictures on a dyno post, but there should be.  ;)
« Reply #3 on: September 27, 2021, 06:03:00 AM »
I didn't get any in full dress on this one, was fighting a distributor issue (Pertronix was bad) and was focused on that.
Sand hauler
« Reply #4 on: September 27, 2021, 11:48:57 AM »
Very nice 🙂
Bobby-   Carlsbad, NM
