Author Topic: Lykins Motorsports 428PI  (Read 5242 times)
« on: September 18, 2021, 04:38:53 PM »
Performance Summary:
      Cubic Inches:  436             Dyno brand:  Stuska
      Power Adder:                    Where dynoed:  Dale Meers Racing Engines, Buffalo, KY
      Peak Horsepower:  455 @ 5200
      Peak Torque:  511 @ 3200
Engine Specifications:
   Block brand, material, finished bore size, other notes:  Factory C6ME-A, 4.175"
   Crankshaft brand, cast or forged, stroke, journal size:  Scat 3.980"
   Connecting Rods brand, material, center to center distance, end sizes, bolts:  Molnar Ford FE 6.490"
   Piston brand, material (caster, hypereutectic or forged), dish/dome volume, static CR:  Racetec 4032, 1.670" compression height, flat top, 9.8:1
   Main Bearings, Rod Bearings, Cam Bearings brand and size:  Calico coated Clevite main bearings, Calico coated King rod bearings, Durabond cam bearings
   Piston rings brand, size, other notes:  Total Seal, 1.5/1.5/3mm
   Oil Pump, pickup, and drive:  Melling M57B, Melling pickup
   Oil pan, windage tray, oil filter adapter:  Scott Drake factory replacement pan
   Camshaft brand, type (hyd/solid, flat tappet or roller), lift and duration (adv and @.050"):  Custom Lykins Motorsports hydraulic roller
   Lifters brand, type:  Morel
   Timing chain and timing cover: Cloyes billet timing set and factory timing cover
   Cylinder heads brand, material, port and chamber information:  C6AE-R
   Flow bench used, location:  Not flowed
   Intake valve brand, head size, stem size:  Custom 2.080", 11/32" stem SI stainless
   Exhaust valve brand, head size, stem size:  Custom 1.560", 11/32" stem SI stainless
   Valve springs brand, part number, specs:  Comp Cams 914
   Retainers and locks brand, part number, specs:  Comp Cams 741, 611
   Rocker arm brand, type (adjustable or non-adj), material, ratio:  Lykins Motorsports non-adjustable roller
   Rocker shafts and stands, brand, material:  POP
   Pushrods brand, type, length:  Trend, custom length 5/16" .080"
   Valve covers, brand, type:   Cobra Lemans
   Distributor brand, advance curve information:  Factory Ford, Pertronix conversion
   Harmonic balancer brand:   Powerbond
   Water pump brand, type (mechanical or electric):   New cast iron replacement
   Intake manifold brand, material, porting information:  Blue Thunder 1x4 MR, not ported
   Carburetor(s) brand, type:  Holley 750
   Exhaust manifolds or headers brand, type:  Dyno headers, 2" tubes
410bruce
Re: Lykins Motorsports 428PI
« Reply #1 on: December 30, 2021, 09:54:38 AM »
This would make an excellent street engine, especially in a heavy car or truck.
I know the high dollar, big hp numbers engines always get the accolades but I love builds like this utilizing mainly factory parts.
Nice one, Brent.
John 3:16
« Reply #2 on: December 30, 2021, 11:30:57 PM »
Nice Brent nice numbers for a dependable motor. Good work
Keith Stevens
« Reply #3 on: December 31, 2021, 12:22:23 AM »
It would be nice to know the duration @ .50 and lift...
