Author Topic: Slick tube valve stem question  (Read 7345 times)
AlanCasida
« on: August 31, 2021, 09:33:46 AM »
I ordered some new M/T slicks and tubes for my car. I am running the old aluminum slot wheels for the vintage look. I noticed the valve stem on the tubes are offset quite a bit to go along with most modern wheels. The valve stem hole in my old slots are pretty much right in the center of the wheel. Is this going to cause a problem or am I over thinking things...as I like to do.
gt350hr
Re: Slick tube valve stem question
« Reply #1 on: August 31, 2021, 09:46:46 AM »
   Go tubeless , you'll be glad you did.
AlanCasida
« Reply #2 on: August 31, 2021, 09:52:49 AM »
I appreciate your input but that's not what I'm asking.  ;)
« Last Edit: August 31, 2021, 10:21:46 AM by AlanCasida »
AlanCasida
« Reply #3 on: August 31, 2021, 10:20:10 AM »
I got ahold of M/T tech and they said it was not a good idea to run the tubes like that. They recommended drilling another hole in the wheel to match the tube and plugging the old hole or running tubeless.  I am going to wait until I get the tires and make sure they even fit with my slots before I make any rash decisions.
« Reply #4 on: August 31, 2021, 11:54:55 AM »
While I don't have experience with tubes in slicks, I do have a lot of experience using them in the equipment at work. It'll cause problems trying to use a tube with a fairly significant offset from valve stem to the hole. It stretches the tube and puts a lot of strain in the rubber surrounding the stem, which will lead to failure in that area. I'd imagine doing the same on a slick that gets launched regularly would lead to failure in a faster time frame.
AlanCasida
« Reply #5 on: August 31, 2021, 12:17:24 PM »
Hey Doug. I saw where you are running the same M/T slicks that I ordered and you are running them without tubes. Do you feel any instability on the top end? When I went from my Hoosier stiff side wall slicks to my friend's M/Ts with tubes I could fell it wobble around a little...enough to notice I guess. I just wonder if it would be more without tubes. I like the looks but these slots are starting to become a pain.
mike7570
« Reply #6 on: August 31, 2021, 12:26:41 PM »
If you are going to run tubes it's important to make sure the tire does not move on the rim. If the tire moves it will pull the tube with it and you run the risk of ripping the valve stem out of the tube.  I ran tubes back in the '80s in my super street car and switched to tubeless once it starting ripping valve stems off.  Rim screws can prevent movement but some guys don't like to drill through expensive wheels.
« Reply #7 on: August 31, 2021, 01:57:18 PM »
I run slots on the car, noticed the same issue.  I have both old ETs and newer American.  I passed on tubes a long time ago.  When I ran slicks I'd make a few passes then flip the tires side for side.  Also note that most tubes need a pretty good sized hole for the stem - more so than a regular tire valve.  The Welds that were on the Mustang were drilled oversize to accommodate the tubes.
« Reply #8 on: August 31, 2021, 07:15:32 PM »
Alan, when I tried 12 lbs in the tire, I definitely could feel rear movement on the top end. Enough that it made me feel uneasy, and I didn't like it. I went back to 15-16 lbs and that feeling went away. I've also tried 14 lbs and didn't feel anything, but it was a nice flat track, so I don't know if would be that way on an older or less optimal track. Between 12 and 15 though, there was a definite difference in sidewall flex at speed. Feeling the rear move side to side at 115+ did not set well with me.
« Reply #9 on: September 01, 2021, 09:19:14 AM »
I don't run those speeds currently, but my Hoosier DRs will 60' the same on a fresh strip at 6 PM on a Friday TnT and at 10:30 PM after all the street cars and diesel trucks have made hay out of the starting line.  And no washing around on the top end.  16 lbs is my target pressure for this car.  Tires are same size as 28-10x15 slicks with little or no growth down track.  I'm at about 460 HP now, if I went to 650 HP tomorrow I'd not change the tires.
gt350hr
« Reply #10 on: September 01, 2021, 09:45:58 AM »
    OK , the stem orientation should match the wheel. You should run a "centered stem" on your wheels. Using an offset stem on a centered wheel hole will fail the tube or tear out the stem as noted on another  post on this thread.
   I have run stiff side wall and soft side walls. At 14psi , I don't get any "wandering " at 122 mph with either style. I did notice a difference in the "hit" of the initial launch with the stiffer sidewall. I run the 10x28 Goodyear (D6 compound) and 60' times are 1.48-1.51 typically. C4 and 5.29 gear.
  Randy
67xr7cat
« Reply #11 on: September 01, 2021, 11:39:17 AM »
Keep in mind reason for inner tube is if the tire doesn't have a semi permable membrane the oxygen molecules can over time get thru the tire meaning the tire looses air pressure over time. If the tire has the membrane is no reason to run an inner tube. The tire mfg. can answer that. If it don't you can still run it without it just will have air it up after few weeks. You can also use the liquid tire sealer will do same job as a tube. Used have a farm tractor kept getting punctured tubes went to the sealer worked great.
« Reply #12 on: September 01, 2021, 02:41:45 PM »
I stopped running tubes in my slicks about 30 years ago, my Fairmont goes 132 MPH in the 1/4 mile, with 10 PSI, no tubes, and no wandering in high gear. Now, if you have radial street tires up front, possibly that could be an issue, maybe. Also, you want to have the rim width closely match the tire width for stability. I went away from tubes because I found over time, the tubes would squirm around inside the tire and throw the balance, causing a high gear vibration. So after so many passes, I would have to take the wheels off the car, let all the air out, and shake the tires to allow the tubes to "flow out" equally again. And true slick tubes are natural rubber, which are heavy, as well as pricey. The weight of those heavy tubes can also negate the benefit of using lightweight wheels well. And if you get a puncture, a tubeless tire will generally go down slowly, but with a tube, will go flat much faster. Plus you need to screw the wheels to the tire beads, otherwise, even a minor amount of the wheel rotating in the tire, will rip the valve stem out. Although M/T says that you should run tubes in most of their slicks, very few people do anymore. Yes, you will likely loose air pressure thru the sidewalls over time, on my Fairmont, which usually runs 10 psi, if it sits in the garage 2 or 3 weeks, they may loose a few psi, not a big deal to me.
« Reply #13 on: September 02, 2021, 06:32:44 AM »
I stopped running tubes in my slicks about 30 years ago, my Fairmont goes 132 MPH in the 1/4 mile, with 10 PSI...
Only 10 PSI, and no wandering? That makes me wonder why mine does. I still have the stock rear leaf hangers, so that may be what's causing mine to wander? I was going to use a set of reinforced hangers when I made some changes, so maybe that will cure it. The shocks are set evenly.
« Reply #14 on: September 02, 2021, 10:26:09 AM »
LOL with slicks - I would usually get 60~100 passes or so on no tube slicks, 12~13 psi, 1.58 60' on the car and the tires be close next time I unlosed the car.  Somewhere north of 60 runs one tire is gonna start losing air between races.  The dragster - old 393C - would 60' around 1.21, 7.5 lbs in a 31x14-15 and the left tire goes flat between races 2 weeks apart.  I load them up to 10 lbs before loading the car.  Right side will go down to about 9 or so over those 14 days.  Left will be about 5.  I have not bothered to do the Dawn dish soap trick where you wipe the inside all over with Dawn which is supposed to reduce the air loss over time.
