Author Topic: Anyone 3D Printing?  (Read 3392 times)
Diogenes
Anyone 3D Printing?
« on: August 26, 2021, 12:21:40 AM »
I just "purchased" the plastic bushings for my Galaxie bellcrank/z-bar (frame side), and am disgusted by the price of these little bits of plastic. Are there any here that are familiar with these pieces and if there is a plastic material robust enough for a 3D printer. I have the new bushings and may set up a 3D printer to reproduce--any thoughts?
« Last Edit: August 26, 2021, 08:25:14 PM by Diogenes »
1985 Toyota Celica Supra
1989 Texas DPS Police Mustang
1971 Torino GT 351C 4V AT
MRadke
Re: Anyone 3D Printing?
« Reply #1 on: August 26, 2021, 09:46:33 AM »
If it's a round bushing, couldn't you get a chunk of appropriate plastic and turn it on the lathe?  I did that for the little plastic wheel on the window regulator on my truck because I didn't want to buy a whole new assembly.
gt350hr
« Reply #2 on: August 26, 2021, 11:36:59 AM »
   That's the way to do it. 3D won't take the load that a stick of Delrin or similar material will take . A screw machine could turn out a hundred in minutes cheaply.
« Reply #3 on: August 26, 2021, 02:20:17 PM »
Agree, 3D is not something you want to put a heavy load on.
Depending on the actual OD and ID, you might find it ready to go at places like McMaster Carr?
Diogenes
« Reply #4 on: August 26, 2021, 07:33:29 PM »
It is not the round bushing. The ball stud on the bellhousing takes the round-ish bushing that is common on Cougars and Mustangs, but the frame side of a 66 Galaxie there is what I would call a plastic sleeve that wraps around the stud (two pieces). See the link below--sorry, I should've included it in the original post.
https://www.ebay.com/itm/324681359706
I know there are different plastics for printing, I'm just not very familiar with it; a friend of mine just bought a printer to work with and parts reproduction is something we've been discussing.
Hell, I should've carved a piece of hardwood--it would've probably worked just fine..
« Reply #5 on: August 26, 2021, 09:36:38 PM »
When I bought my '63 Effie, it used a bracket on the block with the ball you speak of. The previous owner, who'd swapped the '64 390 PI engine in---it had come from the factory as a six---used a bronze split bushing that I found listed as a Thunderbird part. I replaced it while tightening-up the clutch linkage. One put the split bronze around the ball and then pushed the cross-tubing over the OD of the bushing. But three or four months later, I needed to do it again. The ball was damaged to such an extent it simply 'ate' the bronze. I took the bracket off the block and removed the ball. I put a bolt through the hole left, slipped on a washer I made from a piece of bar stock Delrin---drilled the center on my drill-press and then put a bolt and nut through the hole and chucked it up in the DP and used a file on the OD until it fit in the tube. Pushed some grease into the tube for residual lubrication and put it back together. Was still just like that when I sold the truck thirty years later.
Diogenes
« Reply #6 on: August 26, 2021, 11:14:35 PM »
That is an excellent solution, one I will keep in mind if I have a bad ball stud. That material would work for this, though obtaining the correct form would surely be challenging.
fairlaniac
« Reply #7 on: August 27, 2021, 06:25:31 AM »
I've made some in the past with these. Cut the width and drill a hole.
https://www.mcmaster.com/plastic-balls/wear-resistant-easy-to-machine-delrin-acetal-resin-balls/ You can look for different materials. I forget exactly which material I used. It may have been straight Delrin.
« Last Edit: August 27, 2021, 06:28:46 AM by fairlaniac »
Doug Bender
1966 Fairlane 427+/5 Spd TKX
1978 F150 2WD 390
