Author Topic: 427 highriser and built C-4  (Read 2111 times)
Russ67Scode
« on: August 13, 2021, 05:29:41 AM »
1964 454 ci 427 highriser
Built by Panella enterprises has 10 runs  701 hp at 6600 RPM 605 foot pounds of torque at 5000 Crower  4 inch stroke crank ,GRP 6.7 rods,
JE pistons 12.5 to 1
Ford steel highriser heads ported C4AE. “F”
Modified C4D intake
Solid roller cam 276/280 at .050
.690 lift T&D roller rockers
Twin holley 660 Center squirter‘s
PA C-4 with trans brake Coan 8 inch billet stator converter , Turbo Action cheetah shifter.,derale  cooler
16 volt alternator, 16 V XS power D 1600 battery also Schumacher 16 V battery charger
Electric water pump drive
So in essence water pump to transmission tail shaft. And some electrical stuff and shifter
$28000 OBO
This was Phil featherston car/engine
https://youtu.be/fIglXuUdKbk
Ran high nines,10.0 @ 3155 lbs and thru the mufflers   Headers NOT included
rtlm@tampabay.rr.com.       Located in central Florida
« Last Edit: August 13, 2021, 06:14:33 AM by Russ67Scode »
