Author Topic: Blue Thunder intake Oil Fill Tube delete  (Read 3757 times)
Skeeter65
« on: August 08, 2021, 11:16:33 AM »
What’s the preferred method for blocking off the oil fill tube hole on a single 4v Blue Thunder intake if it’s not going to be used? This will be going on the 390 I’m putting in my 67 Mustang and I’ll be filling the oil through the valve cover.
Thanks,
Skeeter65
Re: Blue Thunder intake Oil Fill Tube delete
« Reply #1 on: August 08, 2021, 03:47:18 PM »
A cup plug will do it.
Skeeter65
« Reply #2 on: August 08, 2021, 05:00:09 PM »
Do you know what size it takes ?
« Reply #3 on: August 08, 2021, 05:52:26 PM »
Measure and see but I think it's 1.375".
Skeeter65
« Reply #4 on: August 08, 2021, 06:38:30 PM »
Thanks Brent👍
cheeser
« Reply #5 on: August 09, 2021, 05:46:56 PM »
I purchased this one for my 68 Cougar with 390, but haven’t installed yet.
https://www.summitracing.com/parts/mel-mpc-80b
I’m curious as to the best intake gasket for this setup on a 390?  I’ve held off installing mine as I’ve been a bit paranoid of things not fitting correctly.  From my understanding, these intakes are machined well, so there shouldn’t be an issue on a stock engine.
« Last Edit: August 09, 2021, 05:50:37 PM by cheeser »
