Author Topic: Lykins Motorsports Project Junky Junk 352 Iteration #8  (Read 6425 times)
« on: July 06, 2021, 07:21:58 AM »
Performance Summary:
      Cubic Inches:  359             Dyno brand:  Stuska
      Power Adder:                    Where dynoed:  Dale Meers Racing Engines, Buffalo, KY
      Peak Horsepower:  531 @ 7200
      Peak Torque:  457 @ 5600
Engine Specifications:
   Block brand, material, finished bore size, other notes:  Factory C6ME-A, 4.040"
   Crankshaft brand, cast or forged, stroke, journal size:  FoMoCo cast 352 crankshaft, .020"/.020"
   Connecting Rods brand, material, center to center distance, end sizes, bolts:  Molnar Ford FE 6.490"
   Piston brand, material (caster, hypereutectic or forged), dish/dome volume, static CR:  Racetec 4032, 1.920" compression height, flat top, 10.2:1
   Main Bearings, Rod Bearings, Cam Bearings brand and size:  Calico coated King main bearings, Calico coated King rod bearings, Durabond FP-33 cam bearings
   Piston rings brand, size, other notes:  Mahle 4.040", 1mm/1mm/2mm
   Oil Pump, pickup, and drive:  Melling M57HV, custom pickup, ARP drive
   Oil pan, windage tray, oil filter adapter:  Custom 7 quart pan with oil control gates
   Camshaft brand, type (hyd/solid, flat tappet or roller), lift and duration (adv and @.050"):  Custom Lykins Motorsports solid roller, 256/266 @ .050", 106 LSA, .650"/.670" lift at valve
   Lifters brand, type:  Comp Cams Endure-X
   Timing chain and timing cover: FE Power adjustable timing set and factory timing cover
   Cylinder heads brand, material, port and chamber information:  C6AE-R, JDC Ported
   Flow bench used, location:  Not flowed
   Intake valve brand, head size, stem size:  Custom 2.080", 5/16" stem stainless
   Exhaust valve brand, head size, stem size:  Custom 1.600", 5/16" stem stainless
   Valve springs brand, part number, specs:  PAC small diameter dual spring
   Retainers and locks brand, part number, specs:  Manley titanium retainers, Manley locks, Victory lash caps
   Rocker arm brand, type (adjustable or non-adj), material, ratio:  Modified T&D Street, 1.76:1
   Rocker shafts and stands, brand, material:  T&D
   Pushrods brand, type, length:  Trend, 3/8" .135"
   Valve covers, brand, type:   Chrome PBF
   Distributor brand, advance curve information:  Factory Ford, locked out, Pertronix conversion
   Harmonic balancer brand:   Powerbond
   Water pump brand, type (mechanical or electric):   New cast iron replacement
   Intake manifold brand, material, porting information:  Ported FE Power adapter, ported Weiand 351C Tunnel Ram, 1/2" shear plates, 1/2" opens
   Carburetor(s) brand, type:  (2) Custom Holley 660's from Drew P
   Exhaust manifolds or headers brand, type:  Dyno headers, 2" tubes
Re: Lykins Motorsports Project Junky Junk 352 Iteration #8
« Reply #1 on: July 06, 2021, 07:22:56 AM »
« Reply #2 on: July 07, 2021, 02:16:03 PM »
I swear, Clevelands, FE's and Lima engines are the best looking engines with a tunnel ram. They just look perfect on them.
And I wouldn't have guessed it, but those factory valve covers look pretty darn good on there.
« Reply #3 on: July 07, 2021, 05:07:22 PM »
Thanks, Doug.  I agree, the tunnel rams look great.
gdaddy01
« Reply #4 on: July 07, 2021, 07:04:59 PM »
cast crank , 7200 , tunnel ram , that is beyond cool to me . did I miss it , but what kind of timing ?
« Reply #5 on: July 07, 2021, 07:20:45 PM »
Definetly impressive Brent imagine with 100 more cubic inches.
« Reply #6 on: July 07, 2021, 08:14:01 PM »
Like a lot of factory headed combos, it likes 42°.
« Reply #7 on: July 07, 2021, 08:16:25 PM »
I have thought about that, but I've always been an underdog fan.   It's easy to make horsepower with 445 cubes or 482 cubes, but it takes some thinking and tinkering to make big power with smaller displacements.   In addition, it would be hard for those C6 heads to keep up with a much larger engine.
I built my first FE in 2005.  It was a 428 with Stage 1 KC Edelbrock heads, a solid roller, 11:1 compression, and a Tunnel Wedge with two 725 carbs.  It made 533 hp and 472 lb-ft.   I've learned a lot since then.
gdaddy01
« Reply #8 on: July 08, 2021, 09:43:38 PM »
I would say so .
