Author Topic: Carburetor Question  (Read 16088 times)
JimNolan
Carburetor Question
« on: April 05, 2013, 10:44:42 AM »
I've put some miles on the car now and I've brought it up to 4500 rpm a few times. When doing this I questioned if the secondary on my 750 was really kicking in. The acceleration was smooth but I didn't think the four barrel was kicking in. I put a quick change top on the Secondary Valve Housing and installed a lighter spring. NOW, the secondary kicking in is more pronounced, better acceleration at lower rpm's but you can feel a pulsating in the seat of your pants while it's screaming forward. It seems to be consistent also. HELP what do you guys think.
Re: Carburetor Question
« Reply #1 on: April 05, 2013, 11:07:17 AM »
Sometimes.....a bad spring will allow flutter (fluttering?) of the secondary throttle plate. Try the next stiffer spring (or ligther still) and see if it goes away.
bartlett
« Reply #2 on: April 05, 2013, 06:04:50 PM »
purple spring ... ;D
« Reply #3 on: April 05, 2013, 06:50:33 PM »
I think you need a carb with mechanical secondaries ;D  I know, I'm no help...
Here's a couple of ideas.  If you have access to a GoPro camera, mount it under the hood so that you can see the rod of the secondary diaphragm, and record what is happening.  Or, if you have access to a G-Tech meter, try the different springs and compare the 30-60 MPH times in one gear.  Go with the spring that gives you the fastest acceleration.  Or try the "old-timer's" method, which is to cut a "washer" out of an index card so that the hole in the middle fits tightly over the secondary diaphragm rod, and the outside is maybe 3/8" in diameter.  Unclip the secondary diaphragm rod and install the washer, pushing it all the way up the rod until it contacts the body of the secondary diaphragm housing, then go out and make a run.  If the secondaries are opening the washer will have been forced down the rod as the rod is pulled up into the secondary diaphragm housing.  You will be able to tell how far they are opening by the position of the washer.
« Reply #4 on: April 05, 2013, 08:58:39 PM »
I agree :)
However, as far as your issue, go one spring tighter.  Also make sure that when you changed the cover you didnt lose a corner of the diaphragm, sometimes they can slip when tightening
JimNolan
« Reply #5 on: April 06, 2013, 12:36:48 AM »
Thanks guys,
    I'm running an open air cleaner and Holley says that's the same thing as running a stiffer spring. I'll go another step lighter and see if that don't fix it. I was real careful to get the lid on straight as I've pinched the diaphragm before. Again, thanks.
amdscooter
« Reply #6 on: April 06, 2013, 10:02:59 AM »
Hey Jim, glad to hear you are up and running! Didya ever get a video posted? I'd be real interested to see/hear what she sounds like with our builds being so similar. What did you end up going with exhaust wise?
On a carburetor related note... (and hijacking your thread a bit.. sorry Jim  ;) )  I was wondering what the "mechanical secondaries" crowd recommended? I'm thinking my 600cfm vacuum secondary Holley is a bit smallish even for my mild 390 build and have been shopping Holley 750 double pumpers. As an example, would something like this:
Holley 0-76750BL Model 4150 Ultra Carburetor Blue 750 CFM Double Pumper
http://www.ebay.com/itm/380405064705?ssPageName=STRK:MEWAX:IT&_trksid=p3984.m1423.l2649
Be sufficient? If not what would be a suitable carburetor that you'd recommend? Mild 390 268H cam, Streetmaster, headers, C6 auto. Specific part numbers or linky dinks appreciated.   :)
« Reply #7 on: April 06, 2013, 12:17:00 PM »
It depends.
The DP's are great and really put the power down, but you can do the same with a vacuum carb.
And get a bit better milage. Also if your driving tends to be in town with heavy traffic then the DP is a bit much
for a mild 390.
Here's one with the same colour combo.
It is a Street Avenger and I've had great success with them.
http://www.summitracing.com/parts/hly-0-86770bl/media/images
JimNolan
« Reply #8 on: April 06, 2013, 02:05:53 PM »
Guys,
  Thanks everyone for responding. I'm happy, I'm happy, I'm happy. That sums it up. Went out a couple hours ago and changed my spring to the long yellow one. Reset the idle mixtures with a vacuum gauge. 15" is the most it'd give me. It idles smooth, real smooth. My initial timing is set to 14 degrees with the mechanical welded up for a 10L weight. While I was at it I reset the primary and secondary float bowls have the gas just at the bottom of each glass.
  I buttoned it all up and took it out on the highway. I rolled out in 1st, punched it and power shifted thru three gears to 4500rpm. There were no bogs, no nothing, it was just shit and get it. It's a lot more than what I had in my 300hp 390 but I still don't think it's 415hp like my calculators say. It's more than what my 66 Fairlane GT in 1966 had but I'd not think it's over 375hp. I know one thing. I wouldn't change any part of this build. It runs absolutely fine, cruising to the Drive-In Movie last night it showed how smooth it was on the highway. It'll still be a comfort and enjoyment to drive. I doubt I'll get 20 mpg like I did on the other engine, but I don't care. It'll take more than a paint job to run off and leave me.
  O yes, the sound. It sounds healthy with the exhaust maybe hinting of a large motor but when you turn it loose you'll hear it without any problems a mile away. Sounds good when you're on it. It's twice as loud idling as the other motor. Thanks, Jim  Machoneman,  you were spot on.
bartlett
« Reply #9 on: April 06, 2013, 02:44:17 PM »
4,500 rpm ?  :'(....Let the big dog eat ... 6,000 is more like it  ;D
just givin ya a hard time ... sounds like your getting it dialed in .
JimNolan
« Reply #10 on: April 06, 2013, 09:02:24 PM »
On the way to dinner this afternoon I was doing about 35mph in 4th gear and kicked it to the floor. It accelerated without hesitation and I'd say at about 55mph you could feel the secondary kick in, it wasn't a recognizably drastic change but one that you could feel and it continued to accelerate very well. I'm done. Nothing gets changed. I thought maybe the 750 was going to be a little much for my engine but I think it fits it very well. I think the vacuum secondary is a wise choice if you spend most of your time traveling or cruising. I've never had a mechanical advance before but I can see how accelerating the car at slower speeds could cause problems with a mechanical secondary. It seems to be doing everything it suppose to without any sort of hesitations or burps. Thanks again. Another satisfied customer. See you guys April 27th at Beaver Springs.
Monzy
« Reply #11 on: April 06, 2013, 11:45:08 PM »
I'd say if you've got mechanical secondaries you need to know when you can hit the gas and when you shouldn't.  4th or 5th seeing as you have a tko wouldn't go over very well if you hit the gas to hard at low speeds.  You've got to down shift or flood it out.  I like my mechanical secondaries because I know exactly when they're on or off.
« Reply #12 on: April 07, 2013, 10:19:05 AM »
I wish I knew why mechanical secondaries on an automatic car get such a bad rap.  The old rule of thumb that you should use vacuum secondaries on an automatic and mechanical secondaries on a stick car is a really gross oversimplification, IMO.  I like the positive action of mechanical secondaries, and I've never had a problem tuning a mechanical secondary carb to work on an automatic car.  Jim's combination is pretty mild, and the vacuum secondaries obviously work well, but mechanical secondaries would work fine too.  And I've always found that while vacuum secondary carbs need some signficant tuning to work on most combinations, mechanical secondary carbs are pretty much a bolt on and go proposition.The only thing they really give up is mileage (and who cares about that LOL!).
amdscooter
« Reply #13 on: April 07, 2013, 10:25:24 AM »
Guys,
Nice Jim! About your timing though, am I mis-reading you here? 14 initial and a 10L weight = 24 degrees total advance?  ??? I'm rolling over to the parts store today to pick up a vacuum gauge as I still cannot locate mine. Sounds like you've got her dialed in pretty nicely. I still have a bit of hesitation coming off the line, sometimes I need to feather the throttle a bit to get her rolling. But much like yours, once she gets rolling the acceleration is pretty good. I think the larger double pumper would go a long way to fix most of that issue.
Had a guy pull up next to me in a "70" 440 Roadrunner last weekend on the El Camino. He wanted to go... I dropped it into 2nd and mashed the pedal for about 3 seconds before better judgement took over. But for those 3 seconds...  ;D
amdscooter
« Reply #14 on: April 07, 2013, 10:34:17 AM »
I've come around to that same mindset after reading about the last few weeks. I know a lot of folks say the vacuum secondary carbs can be dialed in nicely.. and I believe them. But the time I'm spending under the hood trying to get my current 600cfm Holley vacuum secondary carb dialed in is time I feel would be better spent just driving the car. I'm probably going to order a 750~800cfm 4150 this week. If I lose a few mpg in the proposition in exchange for some really good off the line performance and a whole lot less tweaking it's a fair trade to me. To be honest I could not tell you what kind of MPG I get. My mindset when I get into the Fairlane is when it gets low on fuel.. I put more in.  ;)
