Author Topic: Fan Shroud for 66 Galaxie w/352  (Read 3220 times)
MRadke
« on: June 21, 2021, 03:10:51 PM »
Has anyone used Rhino Fabrication fan shrouds?  What might my best option be for putting a shroud on my car?  I'm hoping that getting a shroud back on it will prevent it from vapor locking in hot weather/slow speed operation.
GerryP
Re: Fan Shroud for 66 Galaxie w/352
« Reply #1 on: June 21, 2021, 03:55:33 PM »
A shroud won't do anything for vapor lock or carb percolating.  For the carburetor, use an insulating gasket set or an insulating spacer, like wood or phenolic or even plastic.  Look at the routing for your fuel line to make sure it's not touching anywhere on the engine.
MRadke
« Reply #2 on: June 21, 2021, 05:10:08 PM »
The fuel line isn't making contact anywhere and the only time it gives trouble is in idle speed type driving.  Being a convertible, it gets requested for parade duty from time to time, and that's when it acts up.
GerryP
« Reply #3 on: June 21, 2021, 05:13:33 PM »
Okay, so the fuel line isn't touching anywhere.  Do you have an insulator under the carburetor?  Also, what is your base timing?
winr1
« Reply #4 on: June 21, 2021, 08:00:23 PM »
Is your engine temp going up in hot weather, slow speed operation ??
Would this shroud fit your vehicle ??
Measurements are as close as I could get
Width is 29"
Height is 18.5"
Curve on top is 2.75" from the height of 18.5"
Depth is 4.5"
Hole is 18 5/8"
Hole from passenger side is 5"
Hole from drivers side is 3.25"
Mounting holes center to center 19 1/8"
Passenger side mounting hole is 5.25 from side
Drivers side mounting hole is 4.5 from side
Has 3 small holes on right and left side
Surface will clean up ok but there are some scratches and dings
what exercise will reduce breast size
short term exercise goals
Ricky.
upload image online for url
images uplod
web photo hosting
picture sharing img
MRadke
« Reply #5 on: June 21, 2021, 08:55:35 PM »
I think that one is too big.  This is the link to the one that is supposed to fit. https://rhinofabrication.com/product/rf504/  I was just curious about the quality or if there is a better source.
427John
« Reply #6 on: June 25, 2021, 05:42:51 PM »
As was mentioned earlier make sure you ignition timing is advanced enough, late timing can cause excessive underhood temps.
MRadke
« Reply #7 on: June 25, 2021, 07:03:35 PM »
Will do on checking the timing. The new shroud showed up today, but it looks like I'll have to make a couple of rails to get it mounted. When I had the radiator rebuilt a few years ago, the driver's side rail was installed upside down.
