Author Topic: best mechanical fuel pump  (Read 7999 times)
390owner
« on: June 12, 2021, 07:55:17 PM »
I am needing a new fuel pump for my 390. What would you guys suggest. I can get one at the local parts store for around 25 bucks. Or should I go with a holley or something similar
427John
Re: best mechanical fuel pump
« Reply #1 on: June 12, 2021, 08:21:31 PM »
Are you just looking for a stock replacement pump for a stock 390,if so whichever chain store has the best warranty.If your looking for a performance type pump,both the Carter and Holley pumps are both rebuildable,just make sure whichever one you pick has the proper pressure rating unless you plan to run a pressure regulator.
390owner
« Reply #2 on: June 13, 2021, 08:09:28 AM »
What about edelbrock. I found one that has a max pressure of 6 psi which is just right for my edelbrock carb.
« Reply #3 on: June 13, 2021, 09:10:11 AM »
Edelbrock is a very good pump, but you'll need to do some line work.  If its 400-ish HP or less, I would buy a stock replacement and just bolt it on.  Cheaper and no fuss
390owner
« Reply #4 on: June 13, 2021, 12:21:01 PM »
I have a knock off on there now that looks like the edelbrock so I think my lines will hook right up
« Reply #5 on: June 13, 2021, 02:15:07 PM »
I had an edelbrock maybe 525 horse and it was good for about 4 years , I was having a problem and I changed it because I thought it might be the problem. It wasnt but I ended up going electric. I would recommend the Edelbrock. You don’t need a regulator it just bolts up and go.
427John
« Reply #6 on: June 13, 2021, 06:28:18 PM »
I keep forgetting Edelbrock has fuel pumps too.You would think that they tailor them to work with their carbs so that probably would be the best choice.
« Reply #7 on: June 13, 2021, 07:13:09 PM »
i put a mech. carter fuel pump on my 390 back in the late 80s,still works fine on a 400hp 390.never caused any problems,starving or too much-little pressure.best mech i know of.
67xr7cat
« Reply #8 on: June 13, 2021, 07:31:48 PM »
390owner
« Reply #9 on: June 18, 2021, 07:37:37 PM »
Like most men I clocked my new fuel pump installed it then read the instructions. It said I needed to push the pump arm down before tightening the screws. I loosened the screws turned the bottom of the pump where I wanted it then tightened it down. The engine runs fine with a steady 6 psi pressure. Do I need to remove the pump and do like the instructions said or am I good
« Reply #10 on: June 18, 2021, 10:53:47 PM »
Let it go. Have fun
