Author Topic: Large Assortment of FE Parts and 69/70 Mustang Parts!  (Read 3905 times)
CV355
« on: June 07, 2021, 09:22:59 AM »
We're nearing the end of our '69 Mach 1 project and I have a lot of leftover parts- these are either brand new or very low use as indicated.
1969/70 Mustang Parts:
Stock Replacement Scott-Drake Radiator - Ford FE / 69/70 Mustang (Needs a good flushing but is otherwise fine, no fin damage) - $120
69/70 Chrome Export Braces and Hardware - $50
69/70 Chrome Strut Caps - $30
69 20g Gas Tank, Does not include sender, reproduction, has new SecondSkin applied - $100*
69 Fuel Neck - $20
*Note, 69 fuel tanks will fit in a '70 but the fuel neck will need to be replaced
FE-Specific Parts:
FE Water pump - Iron - $30
FE Fuel Necks - Polished Aluminum and Painted - $30 each
*TuffStuff FE Supercool Aluminum Pump - Polished - $100
FE Alternator, Remanufactured - $30
*FE Alternator, TuffStuff Chrome 4-wire - $100
(Pulleys and Brackets for V-belt setup included)
Flexalite Fan and Spacer - $30
FE OEM Style Starter - $40
FE Breather Caps - Ford Racing Open Style - $25 gets both
FE Stinger HEI Distributor and ignition Box - $150
Holley Blue fuel pump and regulator - $60
MSD Pro-Billet Mech Advance distributor 85941 with new black cap - Unopened Box! $300
Moroso Fabricated T-Pan and Oil Pickup with Studs - BRAND NEW, NEVER USED - $325
* = Less than 10 minutes of use, LNIB
1969 Cobra Jet Iron Heads, with valves, springs, etc (disassembled, cleaned) - Open to offers- contact for more information
Universal Parts:
Aeromotive Boost Reference Fuel Regulator- Carb Pressure Range
Comes with AN fittings for inlet, dual outlets, return, and carb AN fittings for -6AN
Brand new, never even mounted
$180 for all of it, well over $350 in parts here.
All prices exclude shipping.
If someone wants to buy the entire lot, I'll put it all on a pallet and give a major discount simply for saving me the trouble.
Located in Liberty SC if someone wants to pick it up locally.
Can get sale references if anyone needs them
Pics:
https://greenville.craigslist.org/pts/d/liberty-ford-fe-and-mustang-parts/7320965544.html
« Last Edit: June 07, 2021, 09:27:46 AM by CV355 »
chilly460
Re: Large Assortment of FE Parts and 69/70 Mustang Parts!
« Reply #1 on: June 07, 2021, 12:47:14 PM »
I'll take the distributor, water pump, and starter if they're available.
CV355
« Reply #2 on: June 07, 2021, 01:57:12 PM »
Hello, everything is available at the moment.  Which distributor and water pump are you interested in?  I have the Stinger and MSD.  As for water pumps, I have an original iron and the new polished Tuff Stuff.
chilly460
« Reply #3 on: June 07, 2021, 02:06:36 PM »
Sorry, rookie move :)
TuffStuff water pump, MSD distributor.  Can email me at leeson7373@gmail.com
CV355
« Reply #4 on: June 07, 2021, 02:19:27 PM »
Will do!
Tommy-T
« Reply #5 on: June 09, 2021, 01:16:17 AM »
Sent you a PM on the Aeromotive stuff.
CV355
« Reply #6 on: June 09, 2021, 06:50:16 AM »
Replied.  Thanks!
70bosscat
« Reply #7 on: June 27, 2021, 12:55:51 PM »
Is that the street/strip T-pan or the road race version?
Thanks,
Ric
