Author Topic: As to engine an head threads .. flow an stuff .. what about 390 CI tests ??  (Read 3276 times)
winr1
I would suppose more than a few have 3.78 stroke mills
What Would the various FE heads do on the above ??
Ricky.
475fetoploader
Similar with less velocity.
1967  519 c.i.  TKX 5 speed
Take a gander through the dyno results page.  One of my 390’s made 540 hp with 10:1 compression, hydraulic roller, Performer RPM, and TFS heads.
From a factory head aspect, it took fully ported CJ heads, a Tunnel Wedge, a point more compression, and a cam that was about 18° bigger on duration to match it.
« Last Edit: June 06, 2021, 06:14:40 AM by blykins »
CaptCobrajet
We did a 390 engine about a year and a half ago that was 397 cubes, 3.78 stroke, iron C4AE-G heads, single carb, .570 lift cam, and 10.45 to 1, that made 622 hp on Bischoff's dyno.  I reckon it just depends on how you go about it, and how you plan to use it.
Blair Patrick
winr1
Have only changed my plans 10 or so times ... lol
Thanks guys
Ricky.
chilly460
I think this is just another no brainer deal with the TFS heads a they have as small or smaller port size as any of the other heads, and marginally larger than ported OEM head that would be anywhere close to them.  For a “small” FE, seems they’re the clear choice.  The only thing I’d ponder is a TFS port made up to support a smaller 2.09 and throat/bowl size that may better match the 390 bore and cubes, but not very likely to happen and I have no clue if its really necessary (just looking at all the stroker small blocks making big power with 2.08s)
