Author Topic: Best FE Heads And Why ?  (Read 39062 times)
427HISS
« on: June 01, 2021, 08:31:56 PM »
What manufacturer do you like the best, and why ?
Which are ready out of the box ?
Are $3,000 heads worth it ?
Is max flow the only factor that matters ?
What makes one manufacturer better than the rest ?.
Can highly polished ports make a big difference in flow ?
How much does port matching matter ?
How do you like the new AFR heads and why ?
chilly460
Re: Best FE Heads And Why ?
« Reply #1 on: June 02, 2021, 12:32:25 AM »
AFR doesn’t make FE heads
« Reply #2 on: June 02, 2021, 06:13:53 AM »
Pretty broad question, what is the intended application supposed to do? A mild cruiser and a 8 second drag car have vastly different head requirements, as does a .030" over 352, compared to a 520 cube engine. Kinda like asking how high is up.
Skeeter65
« Reply #3 on: June 02, 2021, 07:02:22 AM »
Following this to see where it goes... I would like to see AFR get into the FE world as from what I've seen in the small block Ford world, they perform very well.
427HISS
« Reply #4 on: June 02, 2021, 09:13:13 AM »
Sorry, I meant Trick Flow.
427HISS
« Reply #5 on: June 02, 2021, 09:18:58 AM »
Just in general, middle of the road, average, combo of street & racing, low to high rpm....but if you must, on the street, 500-650 HP/TQ.
Ya know, best of all worlds.
GerryP
« Reply #6 on: June 02, 2021, 09:27:43 AM »
With that criteria, I'd go with cammer heads.
Joey120373
« Reply #7 on: June 02, 2021, 12:14:33 PM »
With those criteria, if you have the funds, a set of Blair Patric pro ports would arguably be “the best”.
But I think if you look at the dyno section you will find that the Felony, BBM or trick flow heads are all capable of those numbers. The TF look to offer a bit more bang for the buck with the CNC porting, but they have their quirks.
I think most would agree that the BP PP heads are on another level and are worth the extra money.
There are others out there, the pro-max are not so cheep knock offs of edelbrocks, ( from what I’ve heard, and for the price you might as well just buy a set of the Edelbrocks.
Speaking of Edelbrock heads, out of the box you probably won’t get there, but with some work they have made some serious power.
Take a look at the dyno section and it should give you a pretty good idea of what heads will do what.
chilly460
« Reply #8 on: June 02, 2021, 01:40:58 PM »
His PP cost seems to be a mystery, is it some tightly held number?
« Reply #9 on: June 02, 2021, 01:48:16 PM »
North of 4k
chilly460
« Reply #10 on: June 02, 2021, 02:14:53 PM »
North of 4k
As always, question then becomes how much they'd help the combo at all.  Hard to beat TFS for a typical 445-462ci hydraulic roller'd deal.  I know PP's have made great power on combos that are a notch above this type engine, but at ~600hp you start looking at stock 2 bolt bottom end block survival, so not sure it's worth the expense bolting them on this type deal.  These 4.25" strokers in cheap blocks seem to hit a nice sweet spot for budget, RPM window, lowend torque, and hydraulic roller stability.
« Last Edit: June 02, 2021, 02:16:32 PM by chilly460 »
427HISS
« Reply #11 on: June 02, 2021, 04:13:42 PM »
How much are Blair's pro ports ?
« Reply #12 on: June 02, 2021, 04:44:52 PM »
Blairs PP are more for the "competitor" and not the street/strip car.
They can go into the realm of the Johnny Horton song "North to Alaska" in the lyric "WAY UP NORTH", depending on valves, springs and attention to detail.
« Reply #13 on: June 02, 2021, 10:28:33 PM »
You should take a look at Jay's heads.
475fetoploader
« Reply #14 on: June 03, 2021, 01:00:38 AM »
I must be a hybrid. Since I’m putting them on a mainly street/some strip car. ;)
1967  519 c.i.  TKX 5 speed
