Author Topic: 352 360 horse  (Read 21275 times)
Royce
352 360 horse
« on: May 18, 2021, 06:21:24 PM »
This one is going on the pump Thurs..
It is a stock rebuild of a 360 horse 352 as near to original as I can make it. I have the correct heads, carb, intake, dual point distributor. Cam is a copy of the 406 cam from Holman Moody which most people agree is what came in the 360 horse.. I am going to run through the shorty cast headers into 2.5 inch pipes no mufflers
Deviations from stock: 4.03 bore, about 1/2 point shy on compression.  Previous owner has put  CJ sized valves in the heads.  I will run it on 110.
I plan to optimize the air fuel on the original carb, dial in timing, and maybe try a couple spacers... Then I plan to switch to a Autolite 1.19 carb just for fun.
Guesses are welcome, however no prizes will be given..  Unless I can get Steve Peasley to volunteer for the county fair dunk tank.. Then i could give out a dozen free tries to put him in the drink.
Frankly, looking at the carb and intake manifold, no way this makes 360 horse.
1961 Starliner 390/375 clone
1965 GT40 tribute w/FE
1992 BMW V-12 5.0
2001 Lincoln 5.4 4 cam
2000 Jaguar XK8 (Ford V8)
WerbyFord
Re: 352 360 horse
« Reply #1 on: May 18, 2021, 06:46:57 PM »
So the cam is the 306-306 advertised, 228-228-114 at .050, .298 lobe lift?
Compression ratio?
Deck clearance & gasket thickness?
Piston-to-Bore & Bearing clearances rods/mains?
I ran spacers on the factory 8v LR intake & it did NOT like an open spacer, the air slamming into those 4 little holes really upset it.
I'd try either a 4-hole or a clover-leaf, something to smooth the flow as it slams into the intake.
This will be fun- especially the peak torque with those high-tech C0AE-D chambers.
Re: 352 360 horse
« Reply #2 on: May 18, 2021, 06:54:52 PM »
Looking forward to the results...
Re: 352 360 horse
« Reply #3 on: May 18, 2021, 07:31:41 PM »
Nice, I’ve always hoped someone would build and test one someday.
The least you could do is put up a shrimp cocktail for the winner  ;D
Royce
Re: 352 360 horse
« Reply #4 on: May 18, 2021, 09:13:23 PM »
Well  lets see if I can fill in some blanks  Compression ratio 10.1 I had to deck it .030 and cut the head .030 to get there.. Piston is .030 down the bore and I have a .020 head gasket Bearings are .0025 rod .0030 main. Did not measure the piston to bore clearance    Relied on the machine shop and I forgot the spec. I have a 4 hole 1 inch spacer and a 1 inch clover leaf spacer to try
« Last Edit: May 18, 2021, 09:16:26 PM by Royce »
1992 BMW V-12 5.0
427John
Re: 352 360 horse
« Reply #5 on: May 19, 2021, 12:15:12 AM »
I won't be at all surprised if the Autolite 1.19 outperforms the original Holley.I also won't be surprised if you meet or exceed the factory rating.
Re: 352 360 horse
« Reply #6 on: May 19, 2021, 01:18:58 AM »
358 @ 5500
Re: 352 360 horse
« Reply #7 on: May 19, 2021, 08:31:27 AM »
What ring pack did you get with the pistons?  That will have an affect on the results.
328 hp
Royce
Re: 352 360 horse
« Reply #8 on: May 19, 2021, 08:43:59 AM »
You are close to my Guess Joe.. The rings are the old 5/64 style.  In fact given how short of the 300 horse rating the standard 4bbl 352 was. I would not be surprised if this one was under 325 hp..
1992 BMW V-12 5.0
Tommy-T
Re: 352 360 horse
« Reply #9 on: May 19, 2021, 10:37:17 AM »
Any other "love" given to the cylinder heads other than bigger valves and milling?
Good luck and I'm hoping to see 360hp.
1968galaxie
Re: 352 360 horse
« Reply #10 on: May 19, 2021, 10:40:15 AM »
Cool Build!
Not old enough to remember 360 hp 352.
I would guess 340 hp.
I would also guess this will like plenty of ignition advance too.
shady
Re: 352 360 horse
« Reply #11 on: May 19, 2021, 12:26:23 PM »
361
2021 FERR cool FE Winner
2022 FERR cool FE Winner
2023 FERR cool FE Winner
Royce
Re: 352 360 horse
« Reply #12 on: May 19, 2021, 01:39:09 PM »
Nothing done to the heads beside bigger valves and milling..   I hope my pessimism on the horsepower is proven wrong
1992 BMW V-12 5.0
Re: 352 360 horse
« Reply #13 on: May 19, 2021, 01:48:03 PM »
It should at least make 1 hp per cube I'd think.
Re: 352 360 horse
« Reply #14 on: May 19, 2021, 02:06:25 PM »
347 is my guess
