Author Topic: '60 Ford hood clearance  (Read 3216 times)
allrightmike
« on: May 09, 2021, 11:31:35 AM »
   Will an FE with a Streetmaster intake and Holley with 1" spacer and low restriction air cleaner fit under the hood of a '60 Starliner?
'60 Starliner 427 4speed.
Re: '60 Ford hood clearance
« Reply #1 on: May 09, 2021, 02:34:08 PM »
I don’t have any actual experience with this, so take it for what it’s worth, but since no one else has commented I’ll throw some stuff out there. And it’s been a long time since I took a close look at a “stock” 1960 Ford with FE. I’m just going to arm chair estimate any difference from the stock set up and the Edelbrock.
I think the original casting number for the regular 352 cast iron intake manifold in the 1960 Ford was the C0AE-9425-B. That’s based on casting numbers I’ve been logging the last few years. I didn’t save a picture of one, but I believe they are pretty much the same dimensions & design as the C4SE-9425-A iron intake Jay tested for his book. Looking in the book, The Great FE Intake Comparo ( which everyone should have a copy of, right?  ;D ) Jay has the carb pad height dimensions measured, which diagram the angle of the carb pad too. The C4SE-A intake shows a 3.125” front height and 5.00” rear height. This is measured by laying a straight edge across the carb pad and measuring at the front & back of the intake. The Streetmaster shows dimensions of 4.00” front and 5.875” at the back. So that shows the Edelbrock Streetmaster has the same carb pad angle, but is 0.875” taller. There is a little more set back of the carb on the Streetmaster, that may help a tiny bit with clearance, but just a guess.
The Holley carb and the Ford 4100 4V are the same height from base to air cleaner flange, 3.25”, so basically the carb is a constant in the question.
I don’t know what the ‘60 Ford with regular 352 used for a carb spacer, if any. I took a quick glance in my Ford Parts Book, but I really didn’t see anything listed for that model year, so it may have just had one of those thick insulating gaskets, but I really don’t know. Maybe someone here with an original ‘60 can help us? I measured one of those ‘65 era aluminum carb spacers Ford used that I had laying around, it measured .9375” (15/16”), so roughly the same as the 1” your asking about. But again I don’t know if the ‘60 used a similar spacer. So right now the spacer is the wild card.
You could try measuring how much clearance to the hood you have now, assuming you have a stock engine in your car to check. Again assuming you have a stock assembly to check, you could add your 1” spacer in there, and see how that fits. Then figure the Edelbrock Streetmaster raises it 0.875”.
A person could adjust the spacer size of course, or machine down the carb pad of the Steetmaster, but that is liable to negatively effect the performance characteristics of the Streetmaster.
The other possible intake manifold Ford used in the 1960 model year was the aluminum intake of the 352 360hp engine. Again, I don’t know if that used any spacer stock. The measurements of the 352 HP intake are a straight 4.00” front & back, flat across the carb pad. So that intake has the same front measurement of the Streetmaster, but without the higher rear height. But that shows the higher front height should be a safe fit. Again any spacer is a wild card. And the 352 HP used a Holley.
« Last Edit: May 09, 2021, 02:40:46 PM by thatdarncat »
allrightmike
« Reply #2 on: May 09, 2021, 03:31:09 PM »
  Kevin, thank you for replying. I'm still in the process of assembly on this project (no hood & fender). Using Holley Stealth and '57 T-bird air cleaner Which may be too tall as original 360 HP units are, shall we say, just a little hard to find LOL. I will attempt to attach a photo.
« Reply #3 on: May 09, 2021, 03:51:56 PM »
Nice looking FE for sure.
427John
« Reply #4 on: May 09, 2021, 04:08:19 PM »
The 57 bird lid definitely has a taller dome than the 60HP lid and the element you have isn't helping either,my friend Mike may know the difference in height of the 57 vs 60 lid his HP Sunliner was missing the original lid when he got it and he had to find one it took him  while to find it and he considered using a 57 lid for a while.The HP intake did use a thin spacer and it may have been a wedge shaped one but I can't remember for sure I will check with him on the thickness.What distributor is that you have on your engine?It looks like a later Autolite type dual point vs the earlier deep bowl Fomoco type.He also ran a multi carb setup on it for a while on the 427 he had in it for a while before rebuilding the original 352HP and installing it.I'll try to get the details on what all it had on it over the years and how much hood clearance there was.
allrightmike
« Reply #5 on: May 09, 2021, 04:19:57 PM »
The distributor is a newer standard FE unit that has the vac. advance holes tig'd up and converted to dual points. The engine is a 427 center oiler.
