Author Topic: Fuel pump  (Read 3947 times)
Leny Mason
Fuel pump
« on: May 07, 2021, 08:34:52 AM »
The fuel pump started to leak on my 1969 428 CJ Mustang, I am wondering if some one here sells  pumps, I search it here and didn't find any, thanks Leny.
gt350hr
Re: Fuel pump
« Reply #1 on: May 07, 2021, 10:31:55 AM »
Leny,
   That Carter pump is rebuildable and several Mustang parts vendors have the kits . Virginia Classic Mustang , MAC's , NPD. Takes about an hour once it;s off the car. Very simple to repair.
  Randy
shady
Re: Fuel pump
« Reply #2 on: May 07, 2021, 12:25:30 PM »
Yes do that, new pumps are junk.
2021 FERR cool FE Winner
2022 FERR cool FE Winner
2023 FERR cool FE Winner
Leny Mason
Re: Fuel pump
« Reply #3 on: May 08, 2021, 09:07:36 AM »
Mine that is on the car is a press together one, so it should be a screw together one ?
427John
Re: Fuel pump
« Reply #4 on: May 08, 2021, 06:57:46 PM »
Yes the original 428 CJ pumps were the bolt together/rebuildable high capacity carter pumps.
Leny Mason
Re: Fuel pump
« Reply #5 on: May 09, 2021, 09:06:10 AM »
Thanks I will try and find one.
Re: Fuel pump
« Reply #6 on: May 09, 2021, 09:32:01 AM »
I do not recall the part number, but the pump I have on my 428CJ in my 59, is a Carter that looks identical to the factory CJ fuel pump, except that it has a threaded inlet port, whereas the factory Carter pumps used a pressed in tube. I bought my pump from Summit, and it works great.
gregb
Re: Fuel pump
« Reply #7 on: May 09, 2021, 10:00:30 AM »
Carter M6905..........
gt350hr
Re: Fuel pump
« Reply #8 on: May 10, 2021, 12:01:37 PM »
 You can swap out the lower portion with the pressed in tube on the new pump.
