FE Technical Forum
Help finding Washers for Blue Thunder style Valve cover bolts
Topic: Help finding Washers for Blue Thunder style Valve cover bolts (Read 4397 times)
ntheogen
Sr. Member
May 06, 2021, 11:41:05 AM »
I just called McMaster-Carr and they do not have these. I am in need of a source for the tiny washers that go under the 3" long bolts that hold down the Blue Thunder style and Fe Power style valve covers. Any help would be appreciated
OD- .495
ID- .350
Thickness- .057
RustyCrankshaft
Re: Help finding Washers for Blue Thunder style Valve cover bolts
Reply #1 on:
May 06, 2021, 05:16:08 PM »
How many do you need? I have a few laying around I can send you I think. I get them at the hydraulic shop and there is one bolt supply house here that has them in stock.
ntheogen
Sr. Member
Reply #2 on:
May 06, 2021, 08:50:12 PM »
2 would work if you could spare them.
CV355
Sr. Member
Reply #3 on:
May 10, 2021, 07:06:23 AM »
Misumi and Essentra Components were my go-tos when McMaster Carr doesn't have simple hardware.
Grainger and MSC are worth a check, but I find their filter methods aren't as great.
ntheogen
Sr. Member
Reply #4 on:
May 10, 2021, 10:53:40 PM »
Thanks FE power forum, Rusty crank has me covered. Much appreciated
FE Technical Forum
