Author Topic: TKO/T5 spacer plate - SOLD  (Read 2350 times)
67xr7cat
« on: May 03, 2021, 10:55:34 PM »
This plate goes between the transmission and bellhousing to space the standard lenght input shaft back so that it will work with an FE bell that has the car toploader spacing. The plate is 3/4" thick. There is some grinding that was done on the inside where the transmission bearing hub goes as it did not fit correctly. This was mocked up to a TKO600 and a lakewood bell for a 460 Ford. I never actually used it, just mock up and has sat on the shelf for 15 years. $110.00 shipped in the lower 48 states.  thank you, Steve
« Last Edit: July 25, 2021, 04:10:47 AM by 67xr7cat »
67xr7cat
Re: TKO/T5 spacer plate
« Reply #1 on: July 07, 2021, 11:26:09 AM »
TTT
67xr7cat
Re: TKO/T5 spacer plate - Sold
« Reply #2 on: July 25, 2021, 04:10:10 AM »
Sold
