Author Topic: TFS head oil restrictors.  (Read 2407 times)
Mbowling
« on: April 29, 2021, 08:34:29 AM »
Do I need to restrict the oil to the rockers on my new Trick Flow heads?  The passage looks noticeably smaller
69 GT500 SCJ
69 merc spoiler II 428SCJ
65 Custom R code
34 ford pu. 286” flat tie
64 brand X corvette
66 mustang coupe 289
79 fiesta turbo
Re: TFS head oil restrictors.
« Reply #1 on: April 29, 2021, 08:40:48 AM »
Yes, and how much depends on the rockers and application.
I tap the existing hole for a 12-24 plug or restrictor.  For most applications, a .080” hole in a 12-24 set screw will work......if you are oiling through the heads.
Gaugster
« Reply #2 on: April 29, 2021, 08:43:14 AM »
From what I gather it will depend on component selection for the rest of the valve train. What are the other components such as lifters, pushrods, oil pump etc.... In any event it seems ideal to drive the oil pump while monitoring pressure and verify a decent amount of oil is getting to the rockers. Brent Lykins has a youtube channel that explains the test well.
