Author Topic: *** SOLD ***Toploader, Hurst Super Shifter, Lakewood Bell Housing, Ram clutch,  (Read 4869 times)
fairlaniac
For sale: Ford Toploader 1-3/8 Big In, Big out. Wide ratio 2.78 1st. This was built about 6 years ago. It started as a RUG-M2. I converted to 1-3/8 input shaft and 31 spline main shaft. Dan Williams machined the tail housing for the large bushing and seal plus vent. I have about 900-1000 miles on the build. It was built with new main shaft, Torque lock synchronizer (1-2 & 3-4), new input, new 2 & 3 gear, new cluster gear and shafts, seals, bearings, etc… Three years ago I had it out of my car and put new seals, bearings, etc… and new blocker rings. No other reason than it was out and I am proactive. The trans is excellent. Fits Fairlane, Mustang, Cyclone, Cougar, Falcon ($1250)
Hurst Super Shifter III with custom chromoly tubing shifter rods, spherical rod bearings (heim joints) ,etc… shifts fantastic. You won’t bend this linkage like the Hurst stuff. Has a back up switch and a tab on the reverse shifter rod to activate the back up lights. Has a switched Hurst shifter ball. Be mindful, this shifter will not fit any stock consoles and you will need to open up your tunnel on the driver’s side to clear the shifter and linkage. ($500)
PENDING - Ford FE 352/390/427/428 and other FE blocks, Lakewood Scatter shield – bell housing w/ original Lakewood block plate. Used, SFI (expired). FYI – I don’t give parts the $5 rattle can treatment. You get to see exactly what you are shopping for. No cuts or notches. ($350)
PENDING - Reproduction big in/out clutch fork (Branda 3 yrs. Old) and SKF t/o bearing, replaced bearing last year when I installed my 427. Has about 125 miles on the bearing. ($75)
PENDING - Ram Clutch 11” 1-3/8-10. Pressure plate rebuilt by Ram three years ago. Disc in one year old. I put this in last year and got rid of the 6 paddle disc. Street friendlier. PP- 2600 psi, 5/16” bolts. Disc – p/n 311. ($200)
I’ll take ($2100) for everything if it is picked up. I’ll take ($2200) plus shipping if I need to crate and ship.
If you want the trans and shifter the combo price is ($1600) pick up or shipped. Buyer pays shipping.
I have switched to a Tremec TKX so I have no use for these anymore. Not a whole lot of miles on anything. I drive the car about 400-500 miles a year on average.
Shipping from Denver, PA 17517
« Last Edit: April 25, 2021, 06:36:09 PM by fairlaniac »
Doug Bender
1966 Fairlane 427+/5 Spd TKX
1978 F150 2WD 390
Gregwill16
Doug, I'll take the Lakewood, clutch kit, fork and throw out bearing. I assume the transmission is a close ratio? I'll shoot you a PM
fairlaniac
Greg, wide ratio. See your messages.
Doug Bender
1978 F150 2WD 390
LMartell
Sent PM
6667fan
  • Every Second Counts
Nice trans for the money
JB
67 Fairlane 500
482 cid 700/617
10.55@125.74 1.46 60’
is the driveshaft 4 sale.will it fit a 66 comet-fairlane with a toploader?
fairlaniac
Driveshaft is not for sale.
Doug Bender
1978 F150 2WD 390
C8OX-FE
Is the shifter still available?
fairlaniac
Yes, the shifter is still available.
Thanks,
Doug Bender
1978 F150 2WD 390
C8OX-FE
Thanks,
PM sent
