Author Topic: Fairlane tires  (Read 4918 times)
Royce
Fairlane tires
« on: April 24, 2021, 05:30:41 PM »
What is the biggest tire wheel combo you can get under a stock 66 Fairlane rear.
1961 Starliner 390/375 clone
1965 GT40 tribute w/FE
1992 BMW V-12 5.0
2001 Lincoln 5.4 4 cam
2000 Jaguar XK8 (Ford V8)
475fetoploader
Re: Fairlane tires
« Reply #1 on: April 24, 2021, 06:29:16 PM »
I had a 275 60 15 comfortably.  A 28x11.50 street tire. The 295 65 15 rubs in about 4 places when I hit a bump.
1967  519 c.i.  TKX 5 speed
475fetoploader
Re: Fairlane tires
« Reply #2 on: April 24, 2021, 06:30:27 PM »
All on a 15x8 wheel.
Royce
Re: Fairlane tires
« Reply #3 on: April 24, 2021, 06:34:48 PM »
Do you know the backspace?
1992 BMW V-12 5.0
JamesonRacing
Re: Fairlane tires
« Reply #4 on: April 24, 2021, 07:03:01 PM »
A 15x8 wheel on a 66 Fairlane needs 4-3/4" backspacing with drum brakes.  Disc brakes are a bit thicker on the hat and will be a 5" backspacing to center between the spring and the wheel lip.
Royce
Re: Fairlane tires
« Reply #5 on: April 25, 2021, 07:54:50 AM »
Thanks guys!!
1992 BMW V-12 5.0
Re: Fairlane tires
« Reply #6 on: April 25, 2021, 08:43:18 AM »
Back in the mid 70s, I had a 6 Fairlane GTA 2 door hardtop. I had L60-15s (about 275/60 15 with the metric tire designations) on MoPar Road Runner ralley wheels, which I believe were 7" wide. At the track, I had 9x28 1/2-15 Firestone Drag 500 slicks, on the same wheels. I seem to recall that I had to bend the outer tab down on the brackets that mount the rubber bump stops about the axle tubes. I may have had to roll the outer wheel well lips, but after 45 years, I can`t say for certain.
