Author Topic: FE diaper  (Read 6072 times)
KMcCullah
FE diaper
« on: April 22, 2021, 09:04:10 AM »
The tech guys at my local track (NHRA) are requiring I put on a diaper. (Insert incontinency joke here ::)) In the past I've been allowed to slide without one since the F100 is street legal. But now we have a new sheriff in town.
Does anyone have a diaper suggestion for a FE with an 8qt rear sump pan? No front or mid plate so it has fit around motor mounts.
Thanks fellers
Kevin McCullah
Re: FE diaper
« Reply #1 on: April 22, 2021, 09:12:06 AM »
With a straight axle it should be a pretty easy fit.  I've contemplated one for the wagon, but with nary 1/2" clearance between the pan and the tubular crossmember I'm not sure how I could get one in there?  I have since changed out the 9 qt deep pan for an 8 qt T pan, so I don't have to worry about scraping the pad on the ground when it comes down from a wheelstand.
Re: FE diaper
« Reply #2 on: April 22, 2021, 09:56:51 AM »
Why my car runs 7.55 in the 1/8, at 7.49 I have to put a diaper on it.  With the Falcon/Fairlane cross member, front deep sump and headers that hug the block, no way.  Note - you could also consider a pan, those are NHRA legal if the pan meets the requirements.  With my rear steer, that's a no-go also.
I can tell you that a generic "small block" diaper fits a full sump deep drag pan on a 351C.  You may have to consider a custom built unit.  Not super expense but not cheap.  But then, neither is tossing a rod and putting the car into the wall.  The diapers work.
Re: FE diaper
« Reply #3 on: April 22, 2021, 10:39:07 AM »
When my racing buddy started running 9’s he had to get one for his car. His is a 351W based SBF in a ‘67 Mustang, but it was custom made and around $200. His engine has both the regular engine mounts and a front plate. It fits nice & snug. You fill out a diagram form with the dimensions you need, it’s not a one size fits all. They can add heat resistant material anywhere that gets close to headers also, his has a section of that. It was made by a company called Russler II. I’ve seen other positive comments on various Internet forums about them. I’ll be going with one on my current FE project too in the not too distant future. The custom diapers aren’t overly expensive as long as you don’t need the SFI rated ones. Here’s the link:
https://russlerii.com/
JERICOGTX
Re: FE diaper
« Reply #4 on: April 22, 2021, 11:46:59 AM »
I use a RussellII on my car. Fits great, and wasn't much more then a poorly fitting one.
Re: FE diaper
« Reply #5 on: April 22, 2021, 10:53:49 PM »
That kinda stuff is a pain in the A**. I had to install a blanket on the trans on my ECTA car. It was more trouble to install than the belly pan.
Hiriser57
Re: FE diaper
« Reply #6 on: April 23, 2021, 07:15:30 AM »
Engine diapers.com can make one.
KMcCullah
Re: FE diaper
« Reply #7 on: April 24, 2021, 09:00:24 AM »
Thanks for the pointers fellers. Will definitely be talking with Russler II.
 The track is mandating a diaper due to several oil downs that happened last year. It took hours to clean each time, which caused the races to run past the county's curfew. I hate the thought of putting a mask over my cross bolts!   >:(
Kevin McCullah
JohnN-1BADFE
Re: FE diaper
« Reply #8 on: April 24, 2021, 09:30:03 AM »
Bandimere?  Is there an E.T. in which they require a diaper?
67 Fairlane GT - 390/451 stroker - 654HP / 552TQ
67 Fairlane S/W - 390/458 stroker with tri-power - 515HP / 595TQ
Re: FE diaper
« Reply #9 on: April 24, 2021, 02:07:01 PM »
Take this as general info, it can probably vary from division to division and track to track. Best is to ask your track or division. I don’t think there’s necessarily a hard ET rule (yet) for the “Lower engine oil-retention device”, the NHRA rulebook states “as required by the class”. For us in division 5 a diaper ( or belly pan as mentioned ) is required 9.99 and quicker for ET bracket cars to run at the division 5 ET Finals event since 2012. NHRA is mostly concerned with the Divisional & National events. It’s the clean up time required for oil downs they want to minimize. For example by the rulebook a diaper is required for Super Street, even though that runs off a 10.90 index, so in that example the 9.99 isn’t the deciding factor. Beyond the National & Divisional events I think NHRA is still letting the tracks decide if they institute a rule for it at their local events. From what I’ve seen most of the bigger tracks have been moving to the diaper from 9.99 & quicker, but I’ve seen reports of tracks requiring them for 10.99 & quicker too. Best is to check your local track guidelines. I don’t think it’s been an issue at Beaver Springs for the FE Race & Reunion, but we didn’t go last year, and I don’t think it’s been pushed at Hot Rod Dragweek either, although that didn’t run last year.
« Last Edit: April 24, 2021, 02:09:49 PM by thatdarncat »
JERICOGTX
Re: FE diaper
« Reply #10 on: April 26, 2021, 06:09:21 AM »
You're worried about covering your cross bolts with a diaper? Will you be deducted show points for that?
Tracks are limited in time enough the way it is. Only open a few weekends a month, and that is IF weather cooperates. Some tracks have curfews. A diaper can save hours of track time cleanup. 2-3 cleanups per day mean the difference of you getting 1 run in, or a dozen.
Re: FE diaper
« Reply #11 on: April 26, 2021, 08:25:46 AM »
On my brothers Maverick 347 his diaper didn't fit either but had a seamstriss (sp?) looked at it and made a few modifications and now fits better , clears headers , steering components and easily removed for service . Might be something to consider
