FE Power Forums => FE Technical Forum => Topic started by: Dan859 on October 08, 2018, 01:56:22 PM
Title: transmission choices
Post by: Dan859 on October 08, 2018, 01:56:22 PM
Hi Everyone,
I just bought a new project car; 64 Comet Cyclone, stroked 428/462CID, with a newly rebuilt Doug Nash 4+1 overdrive transmission.  I remember there was a transmission thread not too long ago, and that DN transmission got pretty much mixed reviews.  So, my question is, should I keep the DN, or sell it for whatever I can get and then buy another transmission.  If I buy another transmission, should I go for a new TKO 600, or a new Richmond 5 speed?  Thanks, Dan
Title: Re: transmission choices
Post by: FElony on October 08, 2018, 08:25:45 PM
Hi Everyone,
So, stroker stickshift Cyclones are common in Ukraine? Found in between a Lada and a Yugo at the corner resale lot?
Post by: Dan859 on October 08, 2018, 11:06:50 PM
Da, tovarish! My friend Boris tell me, "Daniel, this is Ukraine.  Here, all is possible!  I give you such good deal on Amerikansi avtomobile.  Your friends not even believe it.  And later, to celebrate, drink vodka we must" ;D.
Post by: BattlestarGalactic on October 09, 2018, 09:09:31 AM
Are you sure it is an OD transmission?  Typically they are direct in 5th, thought you can make them OD, but the shift pattern gets weird.  Or is this one of those that came in a Corvette?  If so, then I'd think twice about it.   Might be farther ahead to swap over to a TKO.  Better parts availability.
I like the old school race Nash's.  I run one in the wagon.  Parts are still available in certain places.
Post by: e philpott on October 09, 2018, 01:46:03 PM
I was curious about the 4 + 1 as in Chevy trans or old school 5 speed ?? , My old Doug Nash from my small block Mustang back in the 80's was 1 to 1 fifth gear , no OD ….. if you have to replace the transmission ( Chev 4 + 1 ) I would go Richmond 5 sd OD over the TKO , no tunnel mods ,conventional shifter or even a Long shifter will bolt up ,  split case design is just so easy to work on if needed I would go that route just for that reason  , John V had a post where Liberty preferred the Richmond over the TKO in HP applications
Post by: BattlestarGalactic on October 09, 2018, 02:11:50 PM
Hmm, guess I never knew they made a 5spd OD "new" like that.  Must be something relatively new on the market.   I guess they built it to compete with the TKO?  Interesting.  I remember the 6spd a number of years back, but haven't seen anything about it for quite a while(though they still list it)
I've been through each style, though I am partial to the Nash split case, either would do the trick if you wanted OD.  I do like the external shifter of the nash design.  That internal rail is okay, but I like my old school Hurst.
Post by: e philpott on October 09, 2018, 02:20:11 PM
Larry ,  Richmond been advertising the Super Street 5 speed OD for years in the Jegs catalog , 2.89 , 3.06 or 3.33 first gear ratio , the case has a Main Cap in the center to keep gear train from spreading and they are a little longer than the old style 5 speed
https://www.richmondgear.com/auto-parts-catalog/high-performance-transmission-catalog/
https://www.richmondgear.com/wp-content/uploads/pdfs/richmond/RG22.pdf
Post by: e philpott on October 09, 2018, 02:22:54 PM
About 900.00 more than a TKO but the Richmond comes with a Long Shifter and TKO doesn't come with a shifter at all
Post by: BattlestarGalactic on October 09, 2018, 03:08:09 PM
That lower cluster support has been around for some time.   You definitely need it in a drag racing application.  I actually worked on a Nash for a friend just a couple weeks ago that was like serial #3xx, which is really early and did not have the support in the case.  My case is like #14xx and does.  Likely any Richmond case will have it.
I don't doubt they have been around.   I just never hear anyone ever talk about having one.  It's always "TKO" this and that.
Post by: AlanCasida on October 09, 2018, 05:17:05 PM
Actually the TKO600s do come with a shifter just not a handle. However the Co. I bought mine from included a free shift handle and knob(I used neither).
https://www.bowlertransmissions.com/shop/transmissions/tremec-tko-600-ford-transmission-tcet5008/
Post by: Dan859 on October 10, 2018, 09:57:11 AM
Hi everyone,
I'd like to thank you all for your help and your answers.  Just to try to clear things up, the seller said it is a professionally rebuilt Doug Nash 5-speed with a Mr. Gasket vertical gate 5-speed shifter and boot with stainless steel shift rods with heim joints.  He also said it has a lower first gear, and the rear end has 4.11 gears in it.  I'll talk to him some more, but it sounds like it's a 5 speed overdrive, and not the 4+1.  I don't think I'm going to change the tranny; I'll drive it and see how it goes.  Take care,
Dan
Post by: gt350hr on October 10, 2018, 11:02:19 AM
  Dan the Doug Nash 5 speed is a very good transmission. In pure drag race use , a couple of weaknesses did show up.  Gear deflection was a problem with 8,000+ rpm starts with 14" wide slicks( older Pro Stock use) and output shaft twisting also caused failures. These were most common on "Pro Shifted"  (no synchros) because of the very harsh engagement. Modern jericos suffer breakage for the same reasons. Pro Stock cars now have a little tire spin ( controlled by the wheelie bars) to avoid parts breakage .For any use other than pure drag racing , I think you will be fine. If the trans doesn't have synchros , I would recommend changing it out for something that does again unless it is drag race only.
    Randy
Post by: Dan859 on October 10, 2018, 11:21:38 AM
Thanks Randy.  I'll check on the synchros.  This will be pretty much street-driven, with a day at the track in the Spring, for test and tune day.
Post by: BattlestarGalactic on October 10, 2018, 12:22:34 PM
Doug Nash made street boxes, a friend had one.  Full brass, helical cut gears unlike the race boxes.  This was before Richmond bought them out.  I have some copies of the original paperwork that came with it.
One quick way to know if it is a "race" version is put it in a gear.  If there is lash between input/output then it is a race box.   A synchro'd transmission will not have the slop from the pro shifted style dogs/sliders.
Post by: gt350hr on October 11, 2018, 10:20:51 AM
  Absolutely fact! The race trans had a ton of slop when engaged. The sliders had missing  "teeth"  to be able to engage with the huge lugs on the gears. The Vertical gate shifter is what has me thinking it's a race trans. I could easily be wrong.
Post by: machoneman on October 11, 2018, 12:34:00 PM
Still a big fan of the older, non-O.D. Richmond Street 5-Speed with 1:1 fifth gear. Fit very well in my '70 Mustang with only a tad of hammering in one corner of the tunnel. Did need to widen the left side of the tunnel for the Hurst shifter (had been an auto tranny car though). Strong indeed and better shifting than some say compared to either Tremec tranny. 'Course it was originally a Doug Nash design, well proven on the dragstrip.
Here's an old comparison of the three types (NOT an O.D. Richond btw):  http://www.5speedtransmissions.com/5sp_comparison.html
Post by: BattlestarGalactic on October 11, 2018, 12:39:08 PM
My friend raced his all stock for a number of years with a Vertigate shifter.  He finally had Liberty face plate it and then he didn't have to deal with me putting new brass in it on a regular basis.  Trying to powershift it at 6500 was tough on the brass, and constant replacement was the only way to keep it shifting.
Another friend raced his TKO for years, H pattern shifter and all with no ill effects.  He also got it face plated later on.  He ran in the high 10's with it, but once he went low 10's it was a hand grenade with the pin pulled.  He then got a new GForce GF5R.
Post by: Dan859 on October 11, 2018, 12:52:51 PM
Thanks for the information and the link for the comparisons.  As soon as I can contact the seller and get some further information, I'll post it.  Again, thanks to everyone who posted.
Post by: FElony on October 12, 2018, 03:22:46 PM
Boris really gets around, doesn't he? I'm sure he has posted elsewhere, perhaps on a certain finance and news website...  ;)
OK, here's a lead for someone looking for a solid '64 as a foundation:
https://prescott.craigslist.org/ctd/d/1964-mercury-comet-post/6714320298.html
Post by: Dan859 on October 13, 2018, 02:37:40 AM
Quote
Well, I asked him about that; this is what he told me: "Daniel, Daniel, Daniel.  Your friend, he not know here there are many Boris?  It like in Amerika, there many John.   Of that Boris, yes I know, but he not me.  I? I Boris Goodenov.  Why, you ask, such a name?  Well, I tell you.  Daniel, he come to me as friend.  He say to me, Boris, my friend, please help me find nice klassik car.  Now Boris, he know this is very difficult task, but hey, Daniel is his friend.  So, search he must.  Boris search and search.  He show Daniel Lada, Moskvich, Niva, even Gaz.  No Chaika, Chaika very rare, even more rare than Ukrainian who no drink vodka.  But Daniel not like these cars.  Finally, Boris find very nice 64 Mercury.  She even a Comet! Boris think that a good sign because comets bring good luck.  Yes, it is destiny!  Very happy will be Daniel!  So Boris show Daniel avotomobile.  Daniel look at at car.  He tell Boris it is nice car, but needs much work.  Boris ask Daniel, "car, she have engine yes?" "Yes".  "She have transmission?"  "Yes, but I don't know anything about the transmission."  "Not important, transmission there is.  Is lucky there is transmission, or car would be towed by farm horse.  You want to sit in car and be towed by farm horse?"  "No".  "OK".  "Are all other parts?"  "Yes, but they need to be installed."  "Not important.  Your hands not broken."  "So Daniel, car she is not perfect?"  "Yes, that's true."  "But, car she is good enough?"  "Yes."  So, I like car.  I not perfect, but I Goodenov.
Post by: babybolt on October 18, 2018, 07:45:34 PM
Was told years ago that when Doug Nash was designing the 5 speed box he hired some moonlighting Ford T&C engineers.
Found this interesting technical paper:
http://gearsolutions.com/features/designing-a-bulletproof-manual-transmission/
Post by: Dan859 on October 19, 2018, 12:20:13 AM
That's good information to know.  I guess when I need another transmission, I'll look at the Richmonds.
