FE Power Forums => FE Technical Forum => Topic started by: TimeWarpF100 on August 06, 2014, 12:48:48 AM
Title: Jay or Barry or Others. Need help choosing proper header size for a 482
Post by: TimeWarpF100 on August 06, 2014, 12:48:48 AM
Getting to the point I need to build headers for my 66 f100.
482"
Tunnel Wedge and carbs from Barry
10.41 comp
Heads are also from Barry CNC'd Edels
Cam was made for a stock 427 Cuber so a bit small and may need to upgrade. Suggestions for cam also. Its a Solid Roller
As long as I am having to build headers from scratch I want to be in the ballpark with tube size and length and also collector size and length
(http://img.photobucket.com/albums/v513/CalypsoCoralBoss302/1966%20F100%20482/Transmission/IMG_2635_zps63ad6057.jpg)
Title: Re: Jay or Barry or Others. Need help choosing proper header size for a 482
Post by: ScotiaFE on August 06, 2014, 04:51:05 AM
If it was me, me would just get a set of them truck headers Jay used in his book/test.
They made the most power and where the cheapest. :P
Post by: Barry_R on August 06, 2014, 04:59:26 AM
The heads will fit a 2" pipe nicely - and its a good size for the cubic inch and application.  I have found primary pipe size to be less critical than one might suspect as long as you're within a rational range.
Post by: machoneman on August 06, 2014, 06:04:52 AM
check out Headers by Ed:  http://www.headersbyed.com/__ford.htm
Post by: TimeWarpF100 on August 06, 2014, 09:14:35 AM
Thanks All!
Barry, where is a good place to start with tube length and collector length? I know on this application it may not be that important but would like to be at least in the ballpark.
Post by: TimeWarpF100 on August 06, 2014, 11:53:55 AM
ordered a box of misc 2" mandrel bends, collectors etc
Post by: TimeWarpF100 on August 06, 2014, 02:29:53 PM
Barry, What cam would you recommend for this combo?  When the current cam was chosen it was for 427 Cubes and much more mild. It will most likely never see a drag strip and getting a bit old for something that is hard to drive. A nice solid roller street cam.
Post by: My427stang on August 06, 2014, 04:10:44 PM
What's in it now?
Personally, if a mild cam and a street runner truck, I'd go with a small tube and maybe leave the cam.  With that being said, my high 240's, 110 LSA, .600 lift is very mellow in a 489 and although I think a good 2 inch header would be better, is a monster with regular old street Hookers
Post by: TimeWarpF100 on August 06, 2014, 04:31:15 PM
Current is a Cam Research Solid Roller
.588 I & E
232~236 @ .050
104 Intake
108 Exhaust
.050 IVO 12 Closes 40
.050 EVO 46 Closes 10
It was done for a basically stock bore stroke 427 with only mods a small header and the tunnel wedge setup
Post by: fe66comet on August 06, 2014, 06:40:34 PM
D627 Doug's
Post by: My427stang on August 06, 2014, 09:53:55 PM
How do you intend to use it?  My 445 is pretty similar to that and its good in a 4x4 with an NP435.  If you shifted under 5500, I wouldn't change anything and just buy a set of 1 3/4 off the shelf headers. Although I think that 104 intake is pretty early for so much compression, you may have to roll it back to 108 ICL if its fussy on fuel, it's a decent cam
Otherwise, assuming a rear gear steeper than 3.50, not too much tire and a decent converter, I'd probably shift upwards a little but big single plane and good heads, not sure you need to cam it that much.
My wag would be something around 288 advertised intake, 292 or so exhaust, low 240s for .050, 110 LSA on 106 ICL, keep the lift under .600 for the street.
Post by: TimeWarpF100 on August 06, 2014, 10:48:20 PM
Hot street, cruise night maybe a trip to the chassis dyno for curiosity sake.
I do have a 3:50 gear. Tires most likely will be the 285-40/18 that I already have. A pretty sticky when warm. Goodyear Supercar Tire Bought them cheap
I will worry about breaking a axle as for now they are stock 28 spline. Just want it to have a bit of rhump to it,
I do have power brakes. Truck will be pretty light for a truck. Expecting 3500lb or less
I do have a set of 1 3/4" truck headers which are new but the ports are pretty far off. I do not like the exit point as too close to crossmemeber. Its been a while since I made a set of headers, one of those things I wanted to build my own. Expecting it to take around 40hrs to do.
I do have a nice Billet converter and its a 2400 unit built for my estimated HP etc
Post by: My427stang on August 07, 2014, 06:22:34 AM
Well, going with a better matching header is good.  I don't think you need a lot of primary pipe, but like Barry said just hit the mark close.  I think I'd go 2 inch if doing all the work.  I don't like those short collectors either, my 445 has them.
As far as the cam, if it's a hydraulic block, you could consider a nice hydraulic roller and just go a little bigger, but you really aren't that far off.  Good breathing heads and intake and plenty of lift will let a cam hang in there a lot longer than if that cam was in an iron head/dual plane and your setup should like more or less what you have now.
I am not sure what your advertised numbers are but my hunch is the truck would be a little happier on fuel with the current cam straight up (108 ICL) and power would hang in there slightly longer.  Could even run the lash on the tight side, but in the end it doesn't sound too bad to me and would save you money to just rock it back.
Post by: fastback 427 on August 07, 2014, 08:51:31 AM
Since your intent on making your own headers, wich is way cool 8), can you give them a nice straight shot out of the port? Maybe over the frame fenderwell style like the old l and l 429 headers? Sure you would pick up some ponies right there.
Post by: TimeWarpF100 on August 08, 2014, 11:08:37 AM
Thanks to all for the input!
I had a bone stock medium riser standard bore the only addition was the tunnel wedge and BT BU carbs.
I then sold the NOS BT BU carbs and bought a pair from Barry
Went with a Genesis Block
Barry's CNC'd Edelbrock Heads
4.25 x 4.25 Crank
Diamond Pistons etc
10.41 Comp
And Yeah I did a bit of port work on the NOS Tunnel Wedge Intake Thinking I would pick up worth while power
The cam was for the bone stock 427 so that is why I asked. If I were to change it, now would be the time as I have to pull the front clip to do the headers. (had to assemble so I could move it across country)
Advertised on cam is 288 ~ ~ 292  Lobe lift .340
Lobe Separation 106
It would have worked great probably in the stock bore stock heads 427
I am getting OLD so I wanted something I could just drop in gear and not worry about being too hard to drive.
Tight converter and a 3.50 gear
2" primary is what I ordered in case I want to get a bit more out of it.
I do not see myself going to far from home with this truck. Typical would be 20-25 miles one way tops. Just to a car show, scottsdale pavilions.
My long distance runner~daily driver will be the '66 with the TT 3.5L EcoBoost with a few luxuries.
This 427 truck I may make a few laps at GoodGuys event for giggles but that will be the extent of it.
Would love to drive it or haul it to Knotts show in Cali tho. Never been there but always wanted to go.
Initial plan was to take both trucks to SEMA  . . .
Post by: TimeWarpF100 on August 08, 2014, 11:12:08 AM
I have a set of them but the port is all wrong. I know I could fix it but the collector is in wrong place, pointing in bad direction. Instead of modifying those new 1 3/4" truck headers I will put them on next project a 416 FE into my other daily driver 1966 F100 which will most likely get Jays intake base & who knows . .
By the way Jay never put them on anything larger than the stroker 390 best I can tell. But they did work well on a 425hp engine. I think I will be making a tad more than that. LOL
Post by: My427stang on August 08, 2014, 01:01:45 PM
OK, so I read your cam stuff wrong, thanks for clarifying.
With your additional info, I am not sure I would change anything.  If anything, I may just tight lash it.
Here is why.
1 - The lift should do will with your heads and intake
2 - The tight LSA will make a lot of torque and mid range, probably be downright brutal
3 - The advertised duration is a good match and is high enough to carry the power through what you'll be using if for (gears and truck weight)
4 - Its in there already, always easier than changing
5 - DCR is at 8.12, which is about perfect.
I know .050 sounds  low, but I am not sure it would be worth a cam change without going converter/gearing changes, because the rest matches pretty well.  I think I'd run it, it's not like it'll be tough to do a cam change later if you really hated it, its a F-series.  At worst depending on year the grill and radiator has to come out.
That overlap and 10.41 compression should sound like a monster,  should run well on pump gas, and pull hard. Your comment about get in and drive it makes a lot of sense and this will do well
Post by: TimeWarpF100 on August 08, 2014, 03:11:27 PM
Here is why.
Thanks for your Input!
Its all about the torque for me on this truck. It will seldom see 5-6000 rpm. Typical will be off idle to 3-4000 rpm. If I have to give up a few HP on higher end is ok by me.
I had initially wanted to make 600hp but with the way its setup as long as it has a nice torque band.
Any estimates on HP? TQ?
My Dynomation Software is showing 600 TQ @ 4000 RPM and 580HP @ 5500 RPM
Its showing 40HP gain just in the intake mod.
Software saying 500 TQ will start around 2000rpm.  In the past have found it quite accurate as long as I have accurate inputs.
Shows 500 + TQ from 4000~around 5700
I ordered the newest software and it should be here today. Fun to mess with and will be interesting to compare when I get it on the chassis dyno.
Sound, Torque and drivability are my top 3. Reliable of course too.
I have had enough of the gotta spin a high RPM for power . . . LOL
Post by: My427stang on August 08, 2014, 03:55:46 PM
My electronic guessers are saying around 540 hp at 5200 and between 560-580 ft lb at 4200, above 500 from 3000+.  I'd guess those numbers  at the high end, but it should match your desired RPM pretty well.
It's such a unique cam for a 482 I hope you try to use it and see what it does.  The tight LSA should help the torque and make a nasty sounding idle.
I went the other way with my truck 445, about the same .050 duration, lift, and a 104 intake centerline, but spread the centers t0 112 to make it idle smoother.  It runs GREAT and I don't have the headers, intake or head you have.
Post by: TimeWarpF100 on August 08, 2014, 09:12:48 PM
I know its only bench racing but I have my newest dyno software loaded and the initial info inputs done. Not quite finalized as need to do the compression math part but manually input of actual comp.
Ross, Can I email this info to you to see what your thoughts are?
Now I can mess with all kinds of stuff I could not before.
I have done them before on a earlier version then went to engine dyno then to chassis dyno and found them very very close.
Hopefully I will soon find out. Its fun to mess with if nothing else.
All in all a lot of parameters I can mess with.
I will then go to a chassis dyno to see if numbers are in ball park.
If nothing else it appears the torque will be good for a 3500lb truck!
Post by: My427stang on August 08, 2014, 10:02:22 PM
Sure!
My427stang  at cox.net
Post by: TimeWarpF100 on August 08, 2014, 11:10:02 PM
Sure!
Tried a few times but keeps bouncing back saying file is too large. Gotta figure out how to make it smaller.
Tried both pdf and JPEG
Post by: TimeWarpF100 on August 09, 2014, 01:31:05 PM
Ross,
For some reason am having a issue sending docs to your email.
I did look up the Compression stuff & remembered the reason for the .100 down. It was to double check my math as the initial comp came out to 9 to 1
(combustion chamber issue)
The real specs are. (fixed it in program)
A few pics
Final chamber size  74.0 cc
Dish volume   18.0 cc
Head gasket 4.400 bore x .041 compressed
Deck height of .012
With this info is where I came up with the 10.41 to 1
(http://img.photobucket.com/albums/v513/CalypsoCoralBoss302/1966%20F100%20482/Engine/IMG_0039_zps2fd9c129.jpg)
(http://img.photobucket.com/albums/v513/CalypsoCoralBoss302/1966%20F100%20482/Engine/IMG_0024_zps437ff3dc.jpg)
(http://img.photobucket.com/albums/v513/CalypsoCoralBoss302/1966%20F100%20482/Engine/IMG_0523_zps63ed79cc.jpg)
(http://img.photobucket.com/albums/v513/CalypsoCoralBoss302/1966%20F100%20482/Engine/IMG_0521_zpsbacc40f8.jpg)
Post by: My427stang on August 09, 2014, 02:11:17 PM
I replied to your email, looks good to me!
To add some additional thinking to the decision, we had a discussion on Speedtalk a long while ago on whether equal length tubes were beneficial, same with a balanced length intake, and the answer was, yes, no, it depends LOL
You could put the longer primary tubes to match the shorter intake port lengths to balance the peaks a little, whether it would work or not who knows? or, you could optimize each primary tube to its intake port length which would theoretically make a lower peak overall but a flatter torque and hp curve....maybe LOL
Can't really know without testing, but in the end you are in spitting distance of happiness even if you tried to screw it up LOL
You have a well blueprinted motor that seems to match the end use of the truck, now build a set of headers 2 inch with a 3 inch exhaust and good mufflers it should do great things for you.
Thanks for sharing the program information and all your math, it's always good to talk to guys who don't assume the dimensions on the box.  As you can see, no two end up alike unless you make them exactly the same.
How long until you start building your headers and even more, when do you think it'll run?
Post by: TimeWarpF100 on August 09, 2014, 03:33:55 PM
Thanks for all your help & input!
Goal was to start on it May 1st. Health said no.
Latest was August 1st but have another vehicle in shop that cannot be left outside. Yeah is a chevy . . . Just dont tell anyone! (not mine)
My exhaust parts should be here by this coming wednesday. Chevy should be picked up by then (stored here)
Then I can get to where the '66 is stored and bring it to shop to start the header~exhaust. I need to pull the front clip to paint the core support as when I moved did some assembly to help eliminate damage going across the country.
Much easier building the headers with the front clip off.
I can then of course add the fresh show chrome Mercury script covers, add brake lines, LARGER fuel line.
Truck Box~Bed is still off so should make for building rest of exhaust much easier.
I need to finish up a bit of grinding~welding on bed~box then I can prime paint and install.
Need to finish up inside cab wiring, add heater assy but its getting close.
Engine has never been fired. Hope its ok as been sitting done since 2009. Truck has been out of sight but not Quite out of mind .. Some times it will go months before I even go take a look at it. Gotta just block it out that I own it as drives me nuts not being able to finish it up.
I am hoping to have it running by September 1st. Gotta sell more stuff to finish it. Maybe the 416 FE . .
Post by: TimeWarpF100 on August 09, 2014, 08:14:51 PM
Oh Wow!
Ordered the Shoenfeld header parts lunch time on Wednesday. They told me they would be here next wednesday.
Everything showed today, free shipping!
Time to get busy . . .
WIll have to add to the collectors they are 8"
Post by: TimeWarpF100 on August 17, 2014, 10:27:26 PM
Ordered a box of misc mandrel bends in 1 7/8" also.
I will build a set of step headers. Still working on the pipemax program to get me in ballpark on the lengths . . .
Looks like peak HP will be pretty flat around 5200-5800, with peak closer to 5400.
When PipeMax talks about fps on both intake and exhaust how do I convert from Mach? And at what RPM? At the peak HP?
Post by: jayb on August 18, 2014, 10:06:51 AM
Sorry I'm late to this party; been buried in other stuff.  In a nutshell, I'd stick with the cam you have if you want to power brakes to work reasonably, and I'd probably build a set of 1 7/8" to 2" to 2 1/8" step headers.  Primary pipe length isn't going to be critical; shoot for around 30", but anywhere between 25" and 36" should be fine, and I also wouldn't worry about keeping the tubes all the same length; I think it is more important to get that straight shot out of the port for as long as possible, and then maximize the bend radius of the tubes.  If you can afford a merge collector that would also be a good investment, and a long collector will help you quite a bit; the collector volume is quite a bit more important than the primary pipe length.  If you are going to put mufflers and an exhaust system on the truck (I assume so!) put a crossover pipe at the end of the collectors, to effectively define the collector length.
I think Ross's numbers for HP and torque are probably about right, and bear in mind that a chassis dyno will give you rear wheel HP, while the engine dyno software will give you flywheel HP in most cases.  So don't be disappointed when you get to the chassis dyno and only see 440 HP; that will translate to around 550 HP at the flywheel.
Looking forward to seeing the header pictures and the dyno numbers...
Post by: TimeWarpF100 on August 19, 2014, 12:01:16 AM
Thanks for your input Jay!
I would be happy with 440 at the wheels and 460 or more torque. Although for the $$ spent if thats all it makes would never do it again . .
I was just going by what my mostly stock 427 Comet did.
It made 420hp & 440 tq at the wheels on a 105 deg day with no tuning. Pretty much as I drove it to dyno.
Stock bore 427
Stock unported MR heads
9.6 to 1 comp
6113 Hooker headers
Good 3" exhaust with Dyno Max Ultra Flow mufflers, it did have a crossover.
It had a close to stock solid cam
Stock carbs and MR intake
Stock ignition etc
Again that was with a Top Loader so do expect more loss with the C-6
In the past I have done engine dyno then chassis dyno just to see the loss.
Pretty much all were a 100hp loss with a 4spd and 120 with a c-6  That was 500hp engines.
Looks like my dyno program is a bit HAPPY!
Its typical cool arizona day 1000' elevation, 72 deg temp with 12% humidity.
Typical for the PHX area
I am at 1966' elevation that by itself kills power around 25hp.
If I change the desktop dyno to 2000' elevation, 100 deg F and 30% humidity it drops the numbers to:
548Hp @ 5400 RPM
586 TQ @ 4200 RPM
It shows 438 RWHP & 469 RWTQ
Which is pretty much in ballpark to what Ross/Jay said
Again its just a bench race tool. The real dyno will give me the numbers . . .
I will be very very disappointed if it does not make 460 TQ to the wheels . . I did a LOT better with a Cast Iron D3 head in my 460 pickup . .
Post by: sumfoo1 on August 19, 2014, 06:27:17 AM
you don't put the plug in for the heads?
Post by: TimeWarpF100 on August 19, 2014, 09:50:44 AM
I would assume you are talking about when I cc'd the head?
Look close there is a 3923 or 24 in there . .
Post by: jayb on August 19, 2014, 10:31:36 AM
No way a stockish 427 like the one you described puts down 420 HP at the wheels.  Either that cam was far from stock, or that was one optimistic chassis dyno.  Your 482 will blow away that 427 if its set up correctly...
Post by: TimeWarpF100 on August 19, 2014, 02:39:00 PM
I will try to find the cam card. I do know the 427 Comet was faster than my friends Viper GTS . .
Could have been a happy dyno, a 64 Galaxie single 4v made 400 at the wheels. It was on a stuska dyno first and made 505.
Hopefully will soon find out. The 1 7/8" Misc Mandrel Bends from Schoenfeld showed up today.
Post by: TimeWarpF100 on August 21, 2014, 11:06:05 PM
Found the cam card after quite a bit of looking.   Looks pretty STOCK to me. HAHAHA
This was actually cam 2. Way back in 2002 so the memory slipped along with the racing bench I was sitting on!
One is card I got with cam the other is current. Slightly different specs
Incredible performance with the combo I had at the time.
(http://img.photobucket.com/albums/v513/CalypsoCoralBoss302/1967%20427%20Capri/427CometCamCard82114002.jpg)
(http://img.photobucket.com/albums/v513/CalypsoCoralBoss302/1967%20427%20Capri/427CometCamCard001.jpg)
A Sleeper it was!
(http://img.photobucket.com/albums/v513/CalypsoCoralBoss302/1967%20427%20Capri/2012_07_07_23_53_550011_zps34e513e6.jpg)
Post by: bluef100fe on August 22, 2014, 10:03:48 AM
That's comp cams small drag race grind... Works good in a warmed over 390 also... :)
