FE Power Forums => FE Technical Forum => FE Engine Dyno Results => Topic started by: blykins on October 17, 2025, 08:25:29 AM
Title: Lykins Motorsports 482FE w/ FE Power Tunnel Port Heads 586 hp @ 6000
Post by: blykins on October 17, 2025, 08:25:29 AM
Hate to come in behind Blair's big wampuss cat, but thought I would throw this up here as I think (I could be wrong) it's the first dyno test of Jay's Tunnel Port heads.  Just as a note, no head work was done, the heads were assembled with SI stainless valves and a PAC valve spring package.  No port work.  Factory 1x4 Tunnel Port intake had the floors raised/shaped to match the ports in the heads.
Performance Summary:
      Cubic Inches:  482        Dyno brand:  Stuska
      Power Adder:   Nope         Where dynoed:  Dale Meers Racing Engines
      Peak Horsepower:  586
      Peak Torque:  561
Horsepower and Torque Curves:
Engine Specifications:
   Block brand, material, finished bore size, other notes:  Robert Pond Motorsports Aluminum
   Crankshaft brand, cast or forged, stroke, journal size:  Scat 4340 4.250" Stroke
   Connecting Rods brand, material, center to center distance, end sizes, bolts:  Molnar, 6.700
   Piston brand, material (caster, hypereutectic or forged), dish/dome volume, static CR:  Custom Mahle, 42cc dish, ~10:1
   Main Bearings, Rod Bearings, Cam Bearings brand and size:  Calico coated Clevite main/rod bearings, Durabond FP-01 cam bearings
   Piston rings brand, size, other notes:  Mahle, 1mm/1mm/2mm
   Oil Pump, pickup, and drive:  Melling M57HV, Canton pickup, ARP shaft
   Oil pan, windage tray, oil filter adapter:  Canton front road race, no tray, Scott Drake oil filter adapter
   Camshaft brand, type (hyd/solid, flat tappet or roller), lift and duration (adv and @.050"):  Custom Lykins Motorsports solid flat tappet, 266/280 @ .050"
   Lifters brand, type:  Trend tool steel EDM
   Timing chain and timing cover:  Cloyes timing set, Shelby timing cover, Lykins Motorsports adjustable pointer
   Cylinder heads brand, material, port and chamber information:  FE Power Tunnel Port, SE exhaust ports
   Cylinder head flow in cfm at inches of lift (28" H2O pressure drop):  315/180
   Flow bench used, location:
   Intake valve brand, head size, stem size:  SI stainless, 2.250"
   Exhaust valve brand, head size, stem size:  SI stainless, 1.750"
   Valve springs brand, part number, specs:  PAC
   Retainers and locks brand, part number, specs: PAC
   Rocker arm brand, type (adjustable or non-adj), material, ratio:  T&D Tunnel Port
   Rocker shafts and stands, brand, material:
   Pushrods brand, type, length:  Smith Brothers
   Valve covers, brand, type:  Chrome Pentroof
   Distributor brand, advance curve information:  MSD
   Harmonic balancer brand:  Powerbond
   Water pump brand, type (mechanical or electric):  Edelbrock, also turning alternator
   Intake manifold brand, material, porting information:  Factory 1x4 Tunnel Port
   Carburetor(s) brand, type:  Scott Perkins 850
   Exhaust manifolds or headers brand, type:  Dyno headers
Title: Re: Lykins Motorsports 482FE w/ FE Power Tunnel Port Heads 586 hp @ 6000
Post by: My427stang on October 17, 2025, 12:26:05 PM
Well done!  Healthy single 4 build should make for a happy owner!
Post by: mike7570 on October 17, 2025, 12:36:56 PM
Is the cam duration listed correct?
266/280 @ .050 is a healthy duration to stop at 6,000rpm, especially with tunnel port heads.
Post by: blykins on October 17, 2025, 02:29:27 PM
It is correct.
This is around a 300 cfm head at lift (under 180 on the exhaust side) and you lose about 8-10 degrees of duration at the valve due to valve lash.  It flatlined and held the power to about 6500 rpm, but technically 6000 is the first hp rpm peak.
Post by: jayb on October 17, 2025, 06:17:36 PM
It's too bad that the heads didn't get the bowl cleanup under the valve.  My test heads flowed about 350 on the intake with the 5 angle valve job and the bowl cleanup.  Bet it would have picked up a lot of power with that work.
There's another guy going to the dyno soon with the proper bowl preparation, plus one of my 2X4 intakes.  Looking forward to seeing how that one does...
Post by: Stangman on October 17, 2025, 10:45:03 PM
Nice Brent I guess Jays heads are working well. Only 10 to 1 making good power. Love the flat tap pet to me nothing sounds better not even a solid roller. Was that cam nitride.
Post by: blykins on October 18, 2025, 06:31:50 AM
Yes, nitrided cam, EDM tool steel lifters.
Post by: fitter on October 18, 2025, 05:16:34 PM
Good to see more F E products enter the market. Just curious. Would power level be similar with stock trick flow heads on this build?
Post by: blykins on October 18, 2025, 07:40:32 PM
I would expect more power out of a Trick Flow head.  But as Jay pointed out, this head has nothing done except a good valve job and seats blended in.  The TFS heads are considered “CNC ported”.
An iron block would have made some more hp and I think the 2x4 TP intake would have shown some positive results as well.
This test was done at 180 deg water temp turning the accessories.  It’s really nothing to sneeze at and shows what the heads are capable of with no port work.  I think Joe Craine has ported some that approach 400 cfm or more.
