FE Power Forums => FE Technical Forum => Topic started by: Diogenes on July 27, 2021, 06:31:41 PM
Title: Toploader Rebuild Kit
Post by: Diogenes on July 27, 2021, 06:31:41 PM
Anyone have any suggestions for where to source a good kit? The last one I bought had plastic thrust washers in it, and it seems many available now are the same. I don't want to use plastic washers unless absolutely forced; I re-used my old metal ones with the last rebuild (Cougar--many years ago). Kee looks to be the same, but not sure. They advertise SKF bearings, as if that really matters these days, as they are pretty much all foreign sourced like most.
Any thoughts and suggestions appreciated.
Title: Re: Toploader Rebuild Kit
Post by: garyv on July 27, 2021, 07:34:30 PM
I converted a fairlane toploader to a big in and out a few years back and got everything from David Kee.  I called him
and told him I needed the best stuff he had and it all arrived in a few days.  He was great to deal with and answered all the
questions I had.  All premium parts.
garyv
Post by: Jim Kramer on July 27, 2021, 08:14:04 PM
I bought one from Dave Kee about two years ago......all metal washers, everything fit well.     Jim Kramer
Post by: badd68 on July 27, 2021, 08:20:18 PM
+1 on David Kee!
Post by: 9310alloy on July 27, 2021, 10:50:03 PM
SKF 307 or 209 in max or standard ball bearings still made in USA & they are quality. Nothing wrong with quality plastic thrusts from Kee or Ford.
Post by: cjshaker on July 28, 2021, 01:48:03 AM
Dan Williams has been doing toploader work for as long as David Kee has been alive. The guy is super knowledgeable, very personable and has great customer service. He always talks to customers directly and isn't shy about answering any questions you might have. Nothing wrong with David Kee either, I've used him a few times with no complaints, but sometimes he can be really hard to get ahold of to talk to.
Dans website: https://www.toploadertransmissions.com/
Post by: Diogenes on July 28, 2021, 03:03:08 AM
I've bought from Dan Williams a few times in the past--yes, a very nice guy with a lot of knowledge (in his 70's I believe), but you better have some spare time on your hands, because the old guy will talk your ear off.
Kee's and Williams' kits are $150, which is a fair bit more than some, but worth it if it has the metal thrust washers. I find plastic an unacceptable substitute.
Post by: jwrmach1 on July 28, 2021, 01:19:02 PM
The last kit I got from David Kee had the plastic thrust washers.  I tried to contact him a few months ago about some parts and no answer.  Multiple calls, left a message, and no response.  Tried to order on website and no luck.  It was last winter when the power went out in Texas so I figured I would wait a couple weeks till power was back on things were back to normal and still no way to contact them and no return phone call so  I bought the parts from Dan Williams who was more than happy to do business with me.  Anybody bought stuff from David Kee recently?  Did they suffer from the winter storms?
JWR
Post by: BattlestarGalactic on July 29, 2021, 09:56:15 AM
I met Dan and Dave at Columbus swap meet many years back when we had an "Fe forum" get together/dinner.  I had bought from Dan Williams for years.  Yes, he is a talker, it was a guaranteed 1 hr long distance call(back before cell phones).  I was VERY surprised to see he was NOT an old man like I thought back then.  Now it's been near 20 yrs, but I don't think he was that much older then me back then?  He may be 60 now?  I'm pretty curious to actually know.
Post by: cjshaker on July 29, 2021, 02:31:16 PM
Yep, I went to that dinner, that David was kind enough to pay for. I won't mention where it was at, but Larry probably remembers  :)
Dan has been in the business for over 50 years, so I'm guessing he is in his 70's.
Post by: e philpott on July 29, 2021, 03:00:56 PM
Dan Williams !! eat dinner watch TV , put the kids to bed then call Dan !  he answers the phone unlike Kee
Post by: badd68 on July 29, 2021, 04:01:08 PM
Bummer some have had problems with David! I have also used Dan didn't realize he was still around!!
Post by: ford88 on August 01, 2021, 04:20:26 PM
I build toploaders all the time I prefer the plastic thrust washers.David or Dan have good parts I always order online from Kee and not a problem...Dan is also good and old school
Post by: Diogenes on August 01, 2021, 09:50:11 PM
Why do you prefer plastic?
Post by: ford88 on August 09, 2021, 02:30:42 PM
You dont want metal to metal on cluster or reverse slider.I think the plastic is a improvment over the metal.
Post by: Diogenes on August 09, 2021, 03:30:37 PM
Dan Williams explained it, stating that Ford's original bi-metal thrust washers allowed metal particles to become embedded in the bi-metal material, which in turn caused wear on the connected components. The kit I received from him has steel thrust washers. Dan stated he went from nylon thrust washers to steel due to customer concerns, but said that he is going back to the nylon as it is better.
Post by: SSdynosaur on August 09, 2021, 07:35:15 PM
FoMoCo actually made the composition thrust washers a "running" change used in all toploaders assembled, beginning during the early 1970's (uncertain of the exact date).
Post by: Diogenes on August 09, 2021, 07:55:22 PM
I didn't know that. I've got a set of new nylon washers from a previous build/kit that I'll be using.
