Author Topic: My Tunnel Port Heads Build  (Read 3605 times)
1967 XR7 GT
« on: August 11, 2024, 10:10:46 AM »
I, went with a Set of Jays TP, with SE Exh Ports from his FE Power Cyl Heads
For Valves, I choose Manley's Severe Duty 8mm Hollow Stemmed 2.300" headed Int Valves @ 142g & Manley's Severe Duty 5/16" Stemmed 1.675" Headed Exh Valves @106g
For Valve Guides, I went with C.H.E. Precision Guides, I prefer a Quality Guide, these provide increased wear characteristics due to CHE's proprietary Bronze Blend, which help provide reduced wear, even with todays lifts & spring pressures. Most of this is from their onsite sales pitch.
Stem Seals: It's said the 5/16" seals will work on 8mm valves, but I went ahead and got 8mm seals, because those are what should be used.
I, was able to find a manifold, that I had Vapor Honed.
« Last Edit: August 11, 2024, 10:13:27 AM by 1967 XR7 GT »
Richard
 "Frankly, I'm tired of hearing all the complaints; makes me wonder why I bother hosting this forum."
frnkeore
Re: My Tunnel Port Heads Build
« Reply #1 on: August 11, 2024, 10:33:02 AM »
Very nice!!!
What is the reason that your going smaller on the exhaust valves?
Frank
« Reply #2 on: August 11, 2024, 08:12:36 PM »
Just guessing but probably because he went so big on intake. But I could be wrong.
« Reply #3 on: August 12, 2024, 09:14:03 AM »
Did you have to fill the floor of the intake ?
1967 XR7 GT
« Reply #4 on: August 12, 2024, 10:53:07 AM »
Very nice!!!
The valve spacing on Jay's TPs will allow for a 1.75" valve and will only work on 4.233" bore or larger, but the SE port was designed with the 1.675" valve, because the valve spacing is smaller on Jays FE Power heads so their able to fit smaller bores.
I, chose the 1.675" valve over the others for several reasons, 1st, with the SE Port it already will flow about 240 cfm @ .600" lift, and I believe Jay mention it should support about 900 HP.
I,chose the 5/16" stemmed 1.675" headed valve that weighs 106g, it's 18g lighter than the 3/8 stemmed, 1.75" headed valve @
124g, a 11/32" stem would be a little lighter, as would a 1.71" valve.
Another issue besides weight, a chose the smaller valve because a larger valve increases shrouding issues.
To answer Stangman's Post:
No, I didn't use the 1.675" valve because of the 2.300" Int, actually because of the 1.675" valve, I could of went to a 2.350" valve easily, maybe even 2.400", but then I would definitely would of had shrouding issues.
To answer e philpott's Post:
No, Jays New Aluminum Tunnel Ports, come cast with the Raised Floor on the Intakes.
Richard
« Reply #5 on: August 12, 2024, 11:08:36 AM »
Looks great to me, what are the bolting on to?
frnkeore
« Reply #6 on: August 12, 2024, 12:29:07 PM »
I had to abandon my .309 valves because they were no longer in stock with my valve supplier and would have to wait 4 mo to get them.
I was going to run them with 11/32, 1.75 ex valves, to match in/ex weight, so, I had to buy both at 11/32 and have them drop to Jay so, he can drop ship them to Blair, with the heads, for his 7 angle valve job.
Frank
« Reply #7 on: August 12, 2024, 01:08:36 PM »
Did you have to fill the floor on the intake manifold too ?
1967 XR7 GT
« Reply #8 on: August 12, 2024, 07:14:06 PM »
I, wasn't paying attention before. Yes, I'll have the Int Manifold Ports filled in to match the heads. I, wonder how bad it could be though,  the majority of the flow is at the top of the ports, since the air is being sucked thru the manifold.  Where the Exh has more of an issue since it's being pushed instead of being drawn, mostly.
Richard
frnkeore
« Reply #9 on: August 13, 2024, 01:10:18 AM »
Did Jay mention the push rod mods that you'll have to make on a factory intake, for a ~.700 lift cam?
Frank
« Reply #10 on: August 13, 2024, 04:45:13 AM »
Sometimes you do, sometimes you don't.  Just depends on the lifter, rocker, and pushrod diameter.  I've ran a lot of factory TP intakes with more than .700" lift without having to change/modify the tubes.  Also ran a factory 2x4 dual plane TP intake that needed the tubes modified with just .600" lift.  Lots of variables.
« Last Edit: August 13, 2024, 10:01:06 AM by blykins »
1967 XR7 GT
« Reply #11 on: August 23, 2024, 02:31:07 AM »
Pictures
« Last Edit: August 23, 2024, 02:35:59 AM by 1967 XR7 GT »
Richard
« Reply #12 on: August 23, 2024, 05:21:29 AM »
Are you going to do anything to the casting flash around the outside of yours?
1967 XR7 GT
« Reply #13 on: August 23, 2024, 11:40:01 AM »
Your, talking about what looks like a parting line on the exh side that goes over and connects the exh ports.
I, haven't figured out what to do, if I were to grind it away, the flash would be gone, but where it was ground away would still leave a mark from the grinding, that just replaces the flash, that is still different enough from the rest of the head, which would still be kinda unsightly.
Could paint the heads to cover up the grinding, which would burn away over the exh ports, which would look like crap.
Grinding the rest of the head to match, forget that. I think maybe, wire wheel the rest of the head some what, so as to blend in the grinding so it doesn't stick out as bad, which shouldn't be to work intensive, I think would be the best option.
« Last Edit: August 23, 2024, 11:46:08 AM by 1967 XR7 GT »
Richard
« Reply #14 on: August 23, 2024, 04:17:28 PM »
In a shock tower car you won’t even see it. If the heads work well that’s the important part. I would probably leave it. JMO
1967 XR7 GT
« Reply #15 on: August 29, 2024, 08:16:00 AM »
Exh flow numbers for the FE power Cyl heads, with the SE exh port and 1.675" valve.
Hopefully, the Tunnel Port heads with the SE exh ports (Pictured), will have the flow numbers as good as the FE power heads or at least close. I, am mentioning this because, From what Jay said, their not exactly the same, and so the flow numbers may not be either, and until we have the ports flowed, the numbers are a guess.
Quote
The chamber in my SE and RE heads is better for flow than the tunnel port chamber I designed.  The reason is that the valves are moved towards the intake side of the head, making them closer to the center of the bore with my SE and RE heads.  This allows for a more gradual turn to the deck on those heads than is possible with the tunnel port design, or any FE design for that matter with the stock valve location.
The bottom head is a TP with the stock exh, to compare with a TP with the SE exh.
TP With SE Exh Port
TP With Stand Exh Port
« Last Edit: August 30, 2024, 04:17:12 PM by 1967 XR7 GT »
Richard
hbstang
« Reply #16 on: September 02, 2024, 10:01:21 AM »
funny,that last picture kind of looks like they were 3d printed.
« Reply #17 on: September 02, 2024, 12:11:49 PM »
The casting cores are 3D printed, which helps Jay keep the costs down.
1967 XR7 GT
« Reply #18 on: September 20, 2024, 04:52:22 AM »
I, was thinking new Intake gaskets for the raised port TP's along these lines, some trimming required.
Richard
« Reply #19 on: September 20, 2024, 05:17:54 AM »
When we do “ported” factory TP heads, we always fill the floors and I just use a standard Mr Gasket TP intake gasket.
1967 XR7 GT
« Reply #20 on: September 22, 2024, 05:25:09 AM »
I, thought I would step up and have some ran, since there are none available anywhere. I, bought a set about 6 months ago, Mr. Gasket 205G, a couple months back I was going to pick up a spare set, just to have on hand, but they were no where to be found, so I looked into having some ran, and thought why not fill the gasket in for the raised port.
Richard
« Reply #21 on: September 22, 2024, 05:42:20 AM »
Good idea.
frnkeore
« Reply #22 on: September 22, 2024, 10:33:03 AM »
Richard, are you selling them?
Frank
« Reply #23 on: September 22, 2024, 11:38:23 AM »
Just a FYI for the group, Cometic makes Tunnel Port intake gaskets, and makes them in different thicknesses. They don’t show them in their catalog, but they have the pattern. There may be a slight wait to get them since they’re not a “shelf” item. I have bought them from Cometic because I needed a thicker gasket than the Mr Gasket ones.
1967 XR7 GT
« Reply #24 on: September 24, 2024, 07:15:55 AM »
I, am trying to work out some issues, to keep costs reasonable, if so, I'll have them for sale.
Richard
1967 XR7 GT
« Reply #25 on: September 28, 2024, 10:54:55 AM »
Heads so far.
2.300" Int's
1.675" Exh's
As is, the SE Exh ports flow 240 cfm @ .600" lift.
As is, the stock Int Ports flow 339 cfm @ .600" lift
« Last Edit: September 28, 2024, 11:11:10 AM by 1967 XR7 GT »
Richard
frnkeore
« Reply #26 on: September 29, 2024, 10:26:45 AM »
Richard, are you going to flow them with the 2.3 valves?
Frank
1967 XR7 GT
« Reply #27 on: September 30, 2024, 01:06:39 AM »
I, should have flow numbers after I get them ported.
Richard
