Author Topic: Bullocks Power Service = 462 8-stack Borla EFI, TFS heads, street build  (Read 5029 times)
Performance Summary:
      Cubic Inches: 462           Dyno brand:  Stuska
      Power Adder:    N/A
      Where dynoed:  Dale Meers Racing Engines, Buffalo, KY
      Peak Horsepower:  555 @ 5700
      Peak Torque:  555 @ 4800
Engine Specifications:
   Block brand, material, finished bore size, other notes:  C-scratch 428, 4.160
   Crankshaft brand, cast or forged, stroke, journal size: SCAT 4.25 stroke, 2.20 journal, cast
   Connecting Rods brand, material, center to center distance, end sizes, bolts:  Molnar BBC 6.70
   Piston brand, material (caster, hypereutectic or forged), dish/dome volume, static CR: Mahle 1.325 compression height, 20 cc dish, 10.37:1
   Main Bearings, Rod Bearings, Cam Bearings brand and size:  Clevite rod and mains, Durabond cam bearings
   Piston rings brand, size, other notes: Mahle, 1mm/1mm/2mm
   Oil Pump, pickup, and drive:  Melling M57HV, Canton pickup, POP drive
   Oil pan, windage tray, oil filter adapter:  Canton rear sump, factory oil filter adapter
   Camshaft brand, type (hyd/solid, flat tappet or roller), lift and duration (adv and @.050"):  Custom Bullock's Power Service high vacuum street hyd roller, 231/240 @ .050
   Lifters brand, type:  Morel standard travel
   Timing chain and timing cover: Cloyes 9 position billet and factory timing cover
   Cylinder heads brand, material, port and chamber information:  TFS with blueptinted spring heights and pressures
   Flow bench used, location:  Not flowed
   Intake valve brand, head size, stem size:  TFS standard
   Exhaust valve brand, head size, stem size:  TFS standard
   Valve springs brand, part number, specs:  PAC 155/400
   Retainers and locks brand, part number, specs:  PAC with Manley seals
   Rocker arm brand, type (adjustable or non-adj), material, ratio:  Lykins non-adjustable 1.76
   Rocker shafts and stands, brand, material:  Precision Oil Pumps
   Pushrods brand, type, length:  Trend, 5/16, .080", various lengths
   Valve covers, brand, type:   Lemans Black Crinkle
   Distributor brand, advance curve information:  Holley Dual Sync 20 initial / 35 total, curve managed by Terminator X ECM
   Harmonic balancer brand:   Powerbond
   Water pump brand, type (mechanical or electric):   Edelbrock
   Intake manifold brand, material, porting information:  Borla 8 stack throttle body
   Carburetor(s) brand, type:  8x 58 mm throttle bodies, 8x 47 lb injectors
   Exhaust manifolds or headers brand, type:  Dyno headers, 2" tubes
« Last Edit: March 27, 2023, 03:14:56 PM by My427stang »
Sand hauler
Re: 462 8-stack Borla EFI, TFS heads, street build
« Reply #1 on: September 27, 2021, 11:47:02 AM »
Sweet , good job Ross
Bobby-   Carlsbad, NM
pkm123
« Reply #2 on: September 29, 2021, 10:48:56 AM »
Built a similar motor years ago.  Used 4X 48mm Weber IDA, and later a custom ITB fuel injected 8 stack.  Had older Edelbrock heads that don't flow as well as the TFS.  10.8/1 CR.  Cam was more aggressive 246/254 SR on a 110.  Engine is 452 4.25x3.98.  Made 600 ft. lbs. and 550 hp also. My engine needs more head and larger Throttle bodies to make more HP.  68 Mustang with full interior went 11.3 sec 1/4 mile.   These are torque monsters.  Great build.
