Author Topic: CVF FE Mechanical Water Pump  (Read 5097 times)
Jb427
« on: April 19, 2021, 03:50:02 PM »
475fetoploader
Re: CVF FE Mechanical Water Pump
« Reply #1 on: April 19, 2021, 04:58:47 PM »
Not yet, but I’m definitely interested
1967  519 c.i.  TKX 5 speed
HTRDHARLEY
« Reply #2 on: April 19, 2021, 05:27:31 PM »
Yes, I have run one lots of miles with no issues. Great company to deal with.
cattleFEeder
« Reply #3 on: April 21, 2021, 07:34:00 AM »
I have several of their water pumps been real happy with all of them.
Remember, RPM is your friend
CV355
« Reply #4 on: April 22, 2021, 12:53:54 PM »
CVF makes great products.  I'm running their pulleys and hood hinges.  I already had a TuffStuff chromed aluminum water pump for this build though
« Reply #5 on: April 22, 2021, 10:33:00 PM »
As one way of judging, inquire regarding the construction of the impeller. It's common to have a stamped steel impeller in run-of-the-mill pieces, and a carefully designed cast piece in the quality pumps. When Ebock first offered aluminum FE pumps they used stamped steel, and had a rash of early complaints. When Dove decided to build water pumps he did a design analysis of the impeller from Ford designed to go in the road-racing pump for the Boss 302. He took the design and scaled it to go in the FE article. Worked great.
« Last Edit: April 23, 2021, 10:29:04 PM by cammerfe »
Jb427
« Reply #6 on: April 23, 2021, 09:28:15 AM »
Thanks for all the feedback people
Me too i use there pulleys and brackets on a few cars now they are great to deal with too.
As one way of judging, inquire regarding the construction of the impeller. It's common to have a stamped steel impeller in run-of-the-mill pieces, and a carefully designed cast piece in the quality pumps. When Ebock first offered aluminum FE pumps they used stamped steel, and had a rash of early complaints. When Dove decided to build water pumps he did a design analysis of the impeller from Ford designed to go in the road-racing pump for the Boss 302. He took the design and scaleded it to go in the FE article. Worked great.
Yes i was worried about that too I can't really find anyone unhappy with them touch wood i never had any cooling problems with the 5000cfm derale electric fans i have combined with the radiator that could keep a mack truck cool i was almost running too cold that could change with the new engine but mine could sit and idle in 110 deg c day heat all day long and sit at 160 deg f fan controller would turn the fans off highway driving and it would sit at 180 deg f and come back to 160 deg f soon as you stop. Down side was i only have 1/4" between my shroud + fans and water pump pully there is a set install order or you can't fit it in. I often see day's over 40 deg C 3/4 of the year round so over kill cooling is required here.
