Author Topic: Ford Thompson power steering pump 1966-70  (Read 4141 times)
timvorick
« on: April 04, 2021, 09:34:13 AM »
66 Fairlane GTA Lengendary FORD May/June 2009
I want to share this issue with owners of Ford Thompson power steering pumps from 1966-70.
I found a power steering pump from Lares in Minnesota to solve noisy and other failure issues. They install the Saginaw vane pump internals in the stock Thompson pump housing. Instead of a slipper skirt type cam pack assembly that is no longer available I understand. The noise and pump inconsistency are eliminated. They also have the pump reservoir an exact duplicate of the original. The pump comes with a lifetime warranty (commercial use excluded)
and is a new pump.
Re: Ford Thompson power steering pump 1966-70
« Reply #1 on: April 04, 2021, 09:35:34 AM »
Link?
GerryP
« Reply #2 on: April 04, 2021, 10:04:20 AM »
https://www.larescorp.com/product-categories/power-steering-pumps/
But the whine is how you know a Ford is nearby.  The noise is harmless but this seems to address it if it does bother you.
« Reply #3 on: April 04, 2021, 10:10:30 AM »
Gratias tibi
GJCAT427
« Reply #4 on: April 04, 2021, 10:25:10 AM »
 I`m wondering if this would work with the hydroboost system? It would need 2 return lines.
GerryP
« Reply #5 on: April 04, 2021, 10:44:03 AM »
Sure it would.  You don't need two independent return lines.  You need only to put a T-fitting on the return line to the pump.  I have a hydroboost on a car and this is how that kit was engineered.  Works fine.
« Reply #6 on: April 04, 2021, 12:02:19 PM »
i have a stock 67 fairlane pump with brackets i will never use.is it worth anything?
djburton
« Reply #7 on: April 05, 2021, 07:42:27 AM »
One thing on the Saginaw pump that's kind of important for hydro boost is the external adjustable pressure relief. I wonder if they incorporate that in their Thompson conversion?
