Author Topic: Fe electronic timing  (Read 5544 times)
62f100
  • 714-235-2973
« on: March 16, 2013, 11:33:40 PM »
wondering if anybody wants to share there ignition table. I know it won't be the same as my motor,but at least I'll get a idea of what it looks like. I'm running megasquirt ms3 msx  with mustang cop,crank sensor,semi sequential & home made fuel rail with bung on performer intake.
62f100-352fe ,efi by megasquirt, cop,91 towncar frame&suspension.
Re: Fe electronic timing
« Reply #1 on: March 17, 2013, 08:07:54 AM »
I'd be happy to share mine, but I don't know how to get the table from the MS3X into an electronic format that I can post.  If I can figure that out, I'll put it here...
62f100
  • 714-235-2973
« Reply #2 on: March 17, 2013, 11:33:29 PM »
thanks. also what were you going to / using for a cam sensor? i got a hall effect sensor from digikey,but have to build the circuit & a housing. i already cut down a distributor & made a 50/50 trigger wheel. thank again for your help & this great site,dan.
« Reply #3 on: March 18, 2013, 11:51:02 AM »
For a cam sensor I used a Hamlin 55075 hall effect gear tooth sensor available from Newark, here:
http://www.newark.com/hamlin/55075-ap-02-a/sensor-hall-effect-25-2v-cable/dp/15J7653
If you are going to use it in a distributor you might be able to just drill a hole in the distributor housing and bolt the sensor in place through the hole; it's pretty long.  On my high riser engine I had a Danny Bee belt drive, and I just put a steel tab on the cam pulley, and made a bracket for the sensor so that it pointed towards the tab as it went buy.  Seems to work fine...
62f100
  • 714-235-2973
« Reply #4 on: March 24, 2013, 11:46:49 PM »
ordered some allegro ats627 sensor & going to make a custom piece to go over the distributor plug with the sensor potted in the wall.
