FE Technical Forum
How to remove Cam retaining plate screws?
Pages:
All
Topic: How to remove Cam retaining plate screws? (Read 12704 times)
MeanGene
Re: How to remove Cam retaining plate screws?
Reply #15 on:
March 15, 2021, 04:43:30 PM »
I have one that was done by a Chebbie guy (actually a very skilled builder, but still) and he put the screws in with red Loctite- grrrr. I have gotten the ARP replacements pretty cheap, think it was DSC, IIRC $8 a set
gdaddy01
Reply #16 on:
March 15, 2021, 05:48:17 PM »
this might also loosen up the cam bearings , maybe in drops .
Reply #17 on:
March 15, 2021, 08:23:21 PM »
If you use roller cam bearings (you have to bore out the cam tunnel and regroove as necessary) then you can use a roller thrust plate. Use the 385 pieces---although you'll have to re-locate one of the thrust bolt holes. The cam journals are the right size---but use a steel cam blank instead of an iron one.
Reply #18 on:
March 18, 2021, 01:53:12 PM »
I have the socket but usually use a large screwdriver that had a heck near the handle and put a box end wrench on that. That way i can push in while turning and not strip out the cross.
Pages:
All
FE Technical Forum
