Author Topic: Valve lash with aluminum heads  (Read 6120 times)
Mbowling
« on: March 11, 2021, 12:39:01 PM »
I’m working on my 487 and it’ll have TFS heads.  It’ll have a solid flat tappet and I’m wondering if the called for valve lash should be set the same with aluminum heads vs iron?
69 GT500 SCJ
69 merc spoiler II 428SCJ
65 Custom R code
34 ford pu. 286” flat tie
64 brand X corvette
66 mustang coupe 289
79 fiesta turbo
Re: Valve lash with aluminum heads
« Reply #1 on: March 11, 2021, 12:52:22 PM »
On iron block, aluminum heads, lash will grow .006" when hot.
gt350hr
« Reply #2 on: March 11, 2021, 12:54:15 PM »
  it has to be tighter with aluminum heads . I go .005-.006 tighter "cold" than an iron head. Others will have their opinions. Use of an aluminum block would be tighter yet.
« Reply #3 on: March 11, 2021, 01:16:49 PM »
Yep, about .014" on all-aluminum combo.
Mbowling
« Reply #4 on: March 11, 2021, 01:42:59 PM »
This is going back 20 years but On my 410” all aluminum sprint car motors I’d usually tighten them up by .010-.012.  Which meant with some cams there was zero lash when cold.
69 GT500 SCJ
65 Custom R code
64 brand X corvette
79 fiesta turbo
« Reply #5 on: March 11, 2021, 06:34:33 PM »
I usually see about .008 growth on aluminum head/iron block FE stuff.
On aluminum block/aluminum head I start off at .003 to get .016-.018 hot
« Reply #6 on: March 11, 2021, 07:59:48 PM »
I have been doing 8 on my cold setup with aluminum head/iron block.
66FAIRLANE
  • Andy
« Reply #7 on: March 12, 2021, 01:09:50 AM »
Pretty consistent results. With iron block, aluminium Ebock heads and aluminium Erson rockers I find .007.
« Reply #8 on: March 12, 2021, 05:30:16 AM »
Small fluctuations like that could be the temperature that it's ran at, or even the method that's used to run them.
« Reply #9 on: March 12, 2021, 07:58:42 AM »
Aside from holding a valve open at extremes, or if you are right on the edge of clearance, better too tight than too loose.  -.006 is what I use on iron/alum for initial start, but almost always run lash a little tighter in the end.
« Reply #10 on: March 13, 2021, 07:47:56 PM »
My "number" is 0.007" cold to hot.  That is with a factory iron block, Edelbrock heads, and Dove rocker stands.   No doubt the number is going to vary.  I don't know what my ambient temperature or "hot" temperature really was when I came up with that number anyway.   So for my 0.018" hot lash setting I used to set it to .010" cold.   Theoretically that'd be 0.017" hot.   A little tight is better than a little loose.
pl
« Reply #11 on: March 13, 2021, 07:56:28 PM »
I have the same basic parts. Factory iron block, Ed heads, Erson rockers. I also noticed .007" on mine. Looks like Paulie has the same on his, too.
