Author Topic: FE Stock Shaft Steel Distributor Gears  (Read 11787 times)
Re: FE Stock Shaft Steel Distributor Gears
« Reply #16 on: March 01, 2021, 09:46:33 PM »
That one isn’t for billet cams,  basically a treated stock iron
351crules
« Reply #17 on: March 01, 2021, 10:14:48 PM »
dont billit cams need bronze? steel is for hyd rollers? i mean it looks like a cast gear but the description says can be used on most hyd rollers
« Reply #18 on: March 01, 2021, 10:54:40 PM »
That ad is a little bit of a play on words
“ most hydraulic roller and mechanical roller camshafts with cast gears.”
The key is the part that it says with cast gears. you can use cast on cast, Bronze on steel or steel on steel, However if you use bronze on steel consider it a maintenance item, it will wear and ultimately can leave you stranded. Most of us use steel on steel nowadays, Well, assuming we can get it again or bush like Brent is doing.
351crules
« Reply #19 on: March 02, 2021, 10:15:52 AM »
gotcha..   cam research has them on their website
« Last Edit: March 02, 2021, 10:22:46 AM by 351crules »
« Reply #20 on: March 02, 2021, 10:31:46 AM »
They don't have any and haven't had any for a long time.
babybolt
« Reply #21 on: March 02, 2021, 12:41:18 PM »
Reminds of years ago when I bought a 5.0L GT roller cam engine, back when they were hard to get because of their popularity.  It was supposed to be ready to go, but when I changed the intake the valley was full of small metal particles.  Someone had pulled the stock 5.0L distributor with the steel gear and installed an earlier 289 distributor.  The engine was junk inside, very few salvageable parts.
wayne
« Reply #23 on: March 02, 2021, 02:17:59 PM »
I think we have this figured out - - working along with Brent - more news to come
