Author Topic: FE Stock Shaft Steel Distributor Gears  (Read 11786 times)
« on: March 01, 2021, 10:44:28 AM »
I currently need about 10 steel distributor gears for a .467" distributor shaft but Crane quit making theirs and no one else offers one that I can find.
Does anyone know of any other offering out there?  Has to be steel....no bronze....
I can have some made, but it's a minimum order of (100) and that's a big step to take.
fe468stroker
Re: FE Stock Shaft Steel Distributor Gears
« Reply #1 on: March 01, 2021, 11:17:54 AM »
Brent,  Holley / MSD lists one under the 289 / 302 listing that fits 360 and 390.  .468 ID.  Part # 85833.
« Reply #2 on: March 01, 2021, 11:32:59 AM »
I don't see anywhere in the MSD catalog that PN 85833 will fit the FE distributor.  I have always been under the impression that there was a difference in gear depth/thickness, or pitch between the SBF and FE.  Am I missing something?  I am willing to learn something new if so.  Joe-JDC
« Reply #3 on: March 01, 2021, 11:46:56 AM »
The 351C/460 distributor gear will interchange with an FE, but the Windsors won't.
babybolt
« Reply #4 on: March 01, 2021, 12:26:44 PM »
https://shop.advanceautoparts.com/p/msd-ignition-distributor-gear-ford-351c-460-iron-85812/10211749-P?searchTerm=distributor%20gear
0.531 in. ID;
Distributor Gear Iron; 0.531 in. ID
Distributor Gear; Iron; 0.531 in. ID
Pretty sure the 351C 460 distributor gear is the larger diameter, 0.531"
« Last Edit: March 01, 2021, 12:29:44 PM by babybolt »
« Reply #6 on: March 01, 2021, 01:01:14 PM »
Need steel gear for stock Ford distributor shafts that are .467", not aftermarket shaft size like MSD which is .531".   Joe-JDC
« Reply #7 on: March 01, 2021, 01:11:44 PM »
I've got a couple of good leads.   Will circle back in a bit.
wayne
« Reply #8 on: March 01, 2021, 01:27:06 PM »
 Try Crower cams
y
« Last Edit: March 01, 2021, 01:36:52 PM by wayne »
GerryP
« Reply #9 on: March 01, 2021, 03:13:54 PM »
An undrilled MSD steel gear can be any size you need.  Maybe that's the shortest path to your goal?
« Reply #10 on: March 01, 2021, 04:09:49 PM »
How about some kinda bushing.
« Reply #11 on: March 01, 2021, 04:45:06 PM »
+1 on what Keith said, wouldn't be that hard to put a bushing in there...
« Reply #12 on: March 01, 2021, 05:21:25 PM »
What’s the cost of having them made?
« Reply #13 on: March 01, 2021, 06:33:21 PM »
I'm going to explore the bushing route for now.
I'll open up AutoCAD in the morning, draw something up, and get a quote to have some made.  I'll have enough made to do us all for awhile.
« Reply #14 on: March 01, 2021, 06:43:42 PM »
Working on the problem...
