Author Topic: Cam degreeing  (Read 8984 times)
Re: Cam degreeing
« Reply #15 on: February 28, 2021, 04:32:23 PM »
I did buy the dumbbell lifters that you were selling. I believe they were morels. I don’t know if they are tool steel.Do you still go through the take center springs out ordeal.
Thanks Yellow Truck I will degree it if I get a new cam. To me there’s nothing worse than having to take stuff apart after you carefully put everything together neatly.
« Last Edit: February 28, 2021, 04:34:41 PM by Stangman »
Re: Cam degreeing
« Reply #16 on: February 28, 2021, 04:35:25 PM »
Those are not tool steel.  Yes, I still do a careful break-in, even with the nitrided cams and tool steel lifters.
Re: Cam degreeing
« Reply #17 on: February 28, 2021, 04:50:22 PM »
Ok great thank you guys.
Yellow Truck
Re: Cam degreeing
« Reply #18 on: February 28, 2021, 05:49:48 PM »
At least I learned how to degree a cam. What I'd rather not have learned was how to remove an oil pan and reinstall it in the truck.
Paul.
Re: Cam degreeing
« Reply #19 on: February 28, 2021, 06:04:25 PM »
That's funny....
I will say, when you get off a dyno or a race track though, don't underestimate the difference in 4 degrees of cam timing.  4.56 gears and a loose converter, a little here or there doesn't matter, but if part throttle shifting in the torque curve like we do when going easy in a cruiser or a pickup....104 vs 108 ICL vs 112 is very noticeable, and depending on the combo might be right in either direction.
