Author Topic: 9in Ford Noise  (Read 5627 times)
Cyclone03
9in Ford Noise
« on: February 08, 2021, 07:56:08 PM »
Ive seemed to have pretty good luck with setting up gears,so much so as I do them for friends with no noise problems. But,much like the cobbler with barefoot kids I can’t get my set up quite. I’ve put 3 new sets of gears in this one case and they all scream!
I said case because this weekend it dawned on me the screamer 1 was my old set ,including diff and bearings and retainer I swapped out of a C7 case into an N case it was quite in the old case. I have then over 5 years purchased 3 new sets of gears and installed in this N case all with the same results noise under load (drive side) quite in cost.
This past weekend I pulled it again and ran the pattern,dead center,as a matter of fact the gears had just polished the drive pattern into the gear and the marking compound verified the pattern.
Has anybody had a gear case that was just bad?
Lance H
Re: 9in Ford Noise
« Reply #1 on: February 08, 2021, 10:53:35 PM »
I only use C7 cases and have never had any issues like you describe, even with used 4.11s or new 4.56 gear sets.
Cyclone03
Re: 9in Ford Noise
« Reply #2 on: February 08, 2021, 11:12:35 PM »
That’s what is driving me nuts,I cleaned the rust off a set of gears and installed them for a friend and they didnt scream like the trouble I’m having.
To give you an idea of the noise,my Apple Watch has a Db meter at 75mph gear loaded 82db coast 77!
Lance H
winr1
Re: 9in Ford Noise
« Reply #3 on: February 09, 2021, 12:52:27 AM »
What brand are the noisy gears ??
Will try and find the several forums where folks had noisy gears that would not quite down
Ricky.
Cyclone03
Re: 9in Ford Noise
« Reply #4 on: February 09, 2021, 06:38:18 AM »
Richmond,Summit, and now Eaton.
The Eaton gear had a test pattern when I got them that I matched as best I could.
Lance H
shady
Re: 9in Ford Noise
« Reply #5 on: February 09, 2021, 09:44:06 AM »
2021 FERR cool FE Winner
2022 FERR cool FE Winner
2023 FERR cool FE Winner
gt350hr
Re: 9in Ford Noise
« Reply #6 on: February 09, 2021, 12:46:20 PM »
  Lance,
     Have you checked the "tail bearing" They do wear and "can" cause a load related noise despite a good pattern when checking or when removed to inspect. Even with a Daytona retainer and solid spacer it can happen.
   Randy
Re: 9in Ford Noise
« Reply #7 on: February 09, 2021, 12:52:11 PM »
That's nuts!  Way out of normal.  I typically use Richmond, Strange or Moser.  I never use Summit gears, heard too many iffy stories.
babybolt
Re: 9in Ford Noise
« Reply #8 on: February 09, 2021, 01:11:11 PM »
Heard that US Gear and maybe one other manufacturer are the only US made differential gears.
Cyclone03
Re: 9in Ford Noise
« Reply #9 on: February 09, 2021, 02:02:44 PM »
  Lance,
   Randy
Can’t rule anything out, but I’ve changed it twice,as well as all the other bearings.
It’s maddening.
Lance H
allrightmike
Re: 9in Ford Noise
« Reply #10 on: February 10, 2021, 09:22:54 AM »
My money says you have not forgotten how to set up a ring & pinion, it says the problem is in that case. Maybe pinion center line to carrier center line are out of spec.
'60 Starliner 427 4speed.
Re: 9in Ford Noise
« Reply #11 on: February 10, 2021, 10:21:07 AM »
The case's dimensions may have shifted if it was used in say heavy drag racing/slicks, etc. Try pitching the same gears (lotsa work!) into a different case and see if they don't scream.
gt350hr
Re: 9in Ford Noise
« Reply #12 on: February 10, 2021, 10:54:47 AM »
  Lance,
   Randy
It’s maddening.
      Time to pass the case on to a drag race only ( no mufflers) car , LOL.
70tp
Re: 9in Ford Noise
« Reply #13 on: February 10, 2021, 06:05:05 PM »
I had a case once that , no matter what gear except the one that came out of it, could not be made happy.    Got different case and all was easy
