Author Topic: really long rod stroker 427  (Read 15746 times)
Re: really long rod stroker 427
« Reply #30 on: February 12, 2021, 04:50:37 PM »
Ross, are those bearings for large chamfer, "H" BBC journals?
If so, they would fit the tangs and you would only need to chamfer them in the rod, while narrowing it.
If not, the tangs could prove problematic. I've never done it but, it is sad that you don't need the tangs but, that's makes for, another machining operation.
In general, 7/8 wide rods, need bearings no wider than 3/4.
« Reply #31 on: February 12, 2021, 05:35:49 PM »
Yes, the CB743H is the narrow BBC, had a typo on my phone but that was an actual measurement
How much you had to massage the bearing would depend on the crank and how much you were able to take off the inside of the rods
« Last Edit: February 12, 2021, 05:37:38 PM by My427stang »
« Reply #32 on: February 12, 2021, 07:10:32 PM »
I will check into those bearings. Is that what is normally used on an FE stroker do those cranks have wider journals?
 I mocked up the pistons and crank in the block today. I don't have the 7.1" rods yet (just ordered them from Scat) but with a 6.7" Scat rod it sits just around .400 down. Not exact since the .985" pin is loose in the .990 pin hole but a couple thou deck clearance is not an issue.
« Reply #33 on: February 12, 2021, 09:05:41 PM »
I use those Clevites or ACL on strokers.  Speedpro also makes a narrow bearing
« Reply #34 on: February 13, 2021, 01:09:48 AM »
The position of the bearings, when install in the rod, will tell you how much you need to take of of the inside surface (rod to rod). Measure that first. You can take that down to .005. The the rest will need to be taken from the outside surface. You will need to know, from the manufacturer or measure the filet radius. Then the chamfer has to be,  more than the filet radius, or there will be metal to metal contact, in that area.
« Reply #35 on: February 13, 2021, 09:00:30 AM »
Here are some real pics.  I stuck an H mockup bearing I have in a SCAT BBC H-beam.  Bearing is .835, you need to get rod down to .870
Very little to no room to cut on the inside.  Approx .060 to play on the chamfer side.  You need to cut closer to .110.
I think that even if you eat up the extra on the chamfer side, and reduce the chamfer depth itself  to a minimum, you'll still be into the bearing on one side or the other
I would love if it would work, and you likely could wack the other .050 or so off the inside of every rod and bearing, but seems like a lot of work for not much gain
« Last Edit: February 13, 2021, 09:07:03 AM by My427stang »
« Reply #36 on: February 13, 2021, 01:44:02 PM »
Ross, it looks to me like he has the work in his crank to save, $650 on a crank and $700 or more to save on pistons. I'd say that comes close to $1700. Plus he gets to use the parts he has in the manor he wants.
I get a lot of satisfaction out of doing things like that myself.
Regarding the machine work, that needs to be done. It is rudimentary and can be done at any general machine shop. I would say that the work would take about 3 hours (that's what I would quote, for a job like this) but, to be successful, you have to know the width of the journal and the filet radius.
« Reply #37 on: February 13, 2021, 07:38:07 PM »
Frank, the decision is not mine to judge. However if he could find someone like you to do it, maybe it would be worth it.
I would advise against trying to force it based on having parts, but if you can find a willing machinist, it does look like fun
« Last Edit: February 14, 2021, 01:35:28 AM by My427stang »
winr1
« Reply #38 on: February 14, 2021, 03:10:01 AM »
Tom
How high an rpm are ya looking at an how much does a 7.1 rod weigh if I may ask ??
I might have missed how much the pistons weighed
No access to machine shop tools anymore or I would do for free
I get real interested in builds such as yours
Ricky.
« Reply #39 on: February 14, 2021, 05:04:53 PM »
I don't even see the weight listed for the 7.1 rods. I'd imagine in the LeMans rod territory. The pistons are light to make up for them. It probably won't see high RPM anyways, it's for a street car, but 7000 is plenty safe.
« Reply #40 on: February 14, 2021, 05:11:48 PM »
Got pic's of the pistons, Tom?
pl
« Reply #41 on: February 15, 2021, 06:28:28 PM »
Good news on the rods, they will sell me ones with unfinished pin bushing that come .969" ID so that saves changing them. Not in stock so he says around three weeks. Just need to be narrowed and i'm sure the local machine shop can handle that. Maybe i could even buy the equpment to do it mysef by then.
Pictures of pistons, and the crank.
« Last Edit: February 15, 2021, 06:48:11 PM by TomP »
« Reply #42 on: February 15, 2021, 06:51:56 PM »
As you can maybe see the pistons use pin buttons instead of clips. They also come with a raw dome and since i don't really want a 17 to 1 compression ratio those will be cut down to a flat top.  The oil holes in the road journals didn't migrate out too far.
KMcCullah
« Reply #43 on: February 15, 2021, 08:48:14 PM »
Cool pistons! I'll bet they'll end up pretty light.
Kevin McCullah
« Reply #44 on: February 15, 2021, 08:50:00 PM »
I had a 93 inch Harley shovel head in the early 90’s that made 158 hp that used Teflon buttons instead of a clip , they worked great back then
