Author Topic: Porting Short Port Cylinder Heads?  (Read 7265 times)
410bruce
« on: January 01, 2021, 11:09:45 AM »
Hey Guys! Happy new year.
Just curious if any of you have spent any time porting the short intake port heads. I understand they make good low RPM torque and throttle response and was wondering if one could capitalize on those attributes with port work and adding CJ sized valves.
I'd be happy to be a Guinea pig and send you a set to do up, if it wasn't outrageously expensive or you feel it would be a complete waste of time.   :)
John 3:16
Re: Porting Short Port Cylinder Heads?
« Reply #1 on: January 01, 2021, 11:40:58 AM »
Can you specify what heads you are talking about?  I don't know of any particular FE head that is referred to as a "short port" head...
Dumpling
« Reply #2 on: January 01, 2021, 11:50:58 AM »
Unclear concept of "low-riser" heads?
« Reply #3 on: January 01, 2021, 12:00:32 PM »
I'm guessing 410Bruce is referring to C8AE-H and D2TE heads, with the reduced height intake ports.
It seems everybody is as hung over as I am.  We're a bit slow on the uptake this morning!
« Last Edit: January 01, 2021, 12:02:24 PM by WConley »
410bruce
« Reply #4 on: January 01, 2021, 12:59:33 PM »
Sorry guys, I should have been more clear. WConley is correct. Those style of heads is what I was referring to, specifically a set of C6AE-J or C6AE-U--I have both sets.
John 3:16
Keith Stevens
« Reply #5 on: January 01, 2021, 04:44:39 PM »
Did you look in the exhaust ports in those heads? They both have the large smog nose to my recollection.
427John
« Reply #6 on: January 01, 2021, 05:32:19 PM »
Pretty much any standard FE head after sometime in 1966 falls into that category,of course that doesn't apply to car 427 and 428CJ.1966 is kind of a crap shoot some C6AE heads are tall port some are short port depending on which suffix they are.At stock power levels Ford apparently felt no preference for either since both variations were used on 390 GT's,but guys that raced them in stock classes had a preference for the tall port versions.
Keith Stevens
« Reply #7 on: January 03, 2021, 04:32:57 PM »
I sold Bruce my C6AE-R heads that lacked the "snout" and were 14 bolt pattern. They had 1.66-2.09 valves heads and 71CC chambers with a great multi-angle VJ on them. They ran great on engine. I only changed because of the Edelbrock and weight savings.
427John
« Reply #8 on: January 03, 2021, 08:34:15 PM »
14 bolt C6AE-R's are an example of the coveted tall port GT heads.
« Reply #9 on: January 04, 2021, 04:50:57 PM »
Les Schmader did a set for me, not C6s, but D2s, I run them on my 461 EFI truck motor.  490 HP with a 230/236 112 LSA cam.  They flowed 277 cfm at .550, exhaust was way better than stock but nothing special
I would say if going with any of the more undesirable heads, you should only do so with a reason.  In my case I had truck headers and didn't want to reflange or modify.
C6AE-R, much better head, they can do 15 cfm more reasonably and exhaust is much more capable than -J or -U,
410bruce
« Reply #10 on: January 04, 2021, 08:13:06 PM »
Thanks Ross. My 428 may still end up in a truck and I have truck headers. I don't have Keiths old R heads anymore and I sold the TFS heads I got from Brent when I decided to go a different route with my Cougar.
I do still have those beat up bare CJ heads. I suppose I could dump a bunch of money into them.  :o
John 3:16
Keith Stevens
« Reply #11 on: January 04, 2021, 08:19:14 PM »
They were the large R. They were good running heads. They were the taller LR port design. The exhaust port looked much better than the C7AE-A heads I have.
« Reply #12 on: January 04, 2021, 08:54:48 PM »
C6AE-R is a lowriser port, and generally have an exhaust port that can easily be modified to an early/CJ style.  That's why they are called Poor Man CJs
C7AE-E is a small port like -U, D2, and C8AE-H and has the crappy low exhaust port
Keith Stevens
« Reply #13 on: January 04, 2021, 08:59:34 PM »
Exactly. They ran very well in my opinion but needed a lot of timing. I stumbled onto a set of KBE ported Edelbrocks. I lost some bottom end with the larger valves but they run very well.
« Reply #14 on: January 05, 2021, 12:39:58 AM »
I have some heads with the shorter intake ports but have the higher exhaust ports. C6TE-G i think they are. Buried on a shelf or i'd look right now. In 66 i think all combinations of intake and exhaust ports were available. Aren't the -U the ones with the low exhaust port but tall intakes?
