Author Topic: May 29, 2011 - The Road to Drag Week 2011  (Read 32055 times)
« on: May 29, 2011, 10:24:29 PM »
Unfortunately, I'm still up in the air on this year's Drag Week car, after the rules change in the Modified class that prohibits non-stock strut front suspensions.  After emailing David Freiburger and Rob Kinnan twice last week I finally heard from Freiburger this week.  He asked me to send him some information on the Fatman strut conversion kit that I used, and also some photos of the front suspension of the car.  I did that, but so far nothing back from the Hot Rod guys.  I think they are on a magazine deadline, and also Power Tour starts this coming weekend, so I imagine that they are just buried in work.  But I sure would like to know if they are going to allow my car in Modified or not.
If they don't, I've kind of narrowed down my options to going back with the Galaxie, doing a quick Pinto, or buying a race ready Fox body roller and grafting in the SOHC prior to the event.  I've been looking a little more closely at the Fairmont/Zephyr cars, and have identified a couple that have the equipment I need.  They seem to be available and relatively inexpensive, and I like the idea of running one of those cars rather than a Fox body Mustang.  So I think that if the Shelby clone is a no go in Modified, I can recover in time to go off in another direction if necessary.  Assuming, of course, that the guys from Hot Rod let me know in some reasonable time frame.  Tick, tick, tick...
In the meantime, I'm still proceeding with the Shelby clone, especially since with the bodywork partially completed there's a bunch of bare metal exposed, and I can't leave it like that for any extended period.  This weekend with the extra day tomorrow I've been trying to get the lion's share of the bodywork done, and as of right now things are going more or less according to plan.  I had all the bodywork roughed in by Friday night, so I spent the day Saturday doing touch up on the bodywork and DAing the whole car.  This took most of the day, but by Saturday evening I had the car all cleaned off with wax and grease remover and ready for the first coat of primer-surfacer.  Photo below:
I'm using PPG products on this paint job, so I mixed up some K36/K201 primer surfacer and sprayed the car on Saturday, paying particular attention to the areas with bodywork.  You can really honk this stuff on there and get a high film build thickness, which makes it a lot easier to straighten out the bodywork.  This morning when I went out to the shop the car looked like this:
Today I spent the day wet sanding the whole car with 240 grit, looking for body problems to correct.  The big problem I found was with the driver's side windshield pillar.  The car had been hit here at some point in the past, and when Steve and I were working on it last weekend we discovered a bunch of old bondo here.  Some of it was cracked so it had to come out, and when I did the work on it prior to shooting the primer I didn't get the shape just right; from the front it kind of looked like it had a hook in it.  So I spent a fair amount of time this afternoon reworking that area, but I have it roughed in successfully now and it looks good from all angles.  At the end of the day the car looked like this:
Tomorrow with the day off I plan to continue the bodywork, panel by panel, and fill any pinholes or scratches to basically complete all the filler work.  Tomorrow night I should be able to put on a second coat of primer surfacer, and then the car will be one good wet sanding operation away from being ready for paint.  I'm going to try to get Steve and/or Jerry to come over next weekend and give the car a once over, because it is always good to have another set of eyes on a car before paint (especially when the primary bodywork person is sick of sanding LOL!).
I'll post another update next Sunday (June already!) and hopefully by then I'll know whether I'm going to Drag Week with this car, or if I'll have to switch gears and go another route.
Mario428
Re: May 29, 2011 - The Road to Drag Week 2011
« Reply #1 on: May 30, 2011, 07:53:17 AM »
Man I hate bodywork and you have my sympathy after doing it all weekend.
A wild and crazy thought for you in regards to a Fox body car
This car is available as a loan only will not sell this car, biggest concern is whether the cage would pass tech and sonic check. Was never intended to go more than high 9's.
Needs a lot of TLC now, paint probably but that would be a scuff and spray mostly. Weighs 3100 with an alum headed FE and a 270 lb driver.
More than 2200 miles each way though, got a retired truck driver buddy with nothing to do. LOL
Any interest at all I will take some current pics, lot of parts left that car and went to the T-Bird
« Last Edit: May 30, 2011, 08:00:28 AM by Mario428 »
« Reply #2 on: May 30, 2011, 01:41:02 PM »
Wow Mario, that is just what I am looking for LOL!  What's the story on the cage?  Is it chrome moly or mild steel?  Why are you concerned that it may not pass tech?
Send pics.  Do I understand correctly that you would LEND me this car for Drag Week?  I think it would fit rather nicely into the Pro-Street class...
427Fastback
« Reply #3 on: May 30, 2011, 11:18:51 PM »
I have to say ..thats a outstanding offer from Mario..Its a win win situation for everyone...Sad about the rule changes.All that thrashing and planning only to have the door slammed shut on it..Will you still power the Mustang with a SOHC......Cory
1936 Diamond T 212BD
1990 Grizzly pick-up
« Reply #4 on: May 31, 2011, 08:43:48 AM »
The Mustang will get an SOHC in any case.  The front suspension modifications are done for that reason only, so putting a wedge FE in the car wouldn't really make sense.
I've been in touch with Mario on this a little more, and his car looks like it really would fit the bill, assuming the cage is certifiable to 8.50.
Qikbbstang
« Reply #5 on: May 31, 2011, 10:28:46 PM »
Aghhhhhhhhhhhhhhhhh Just watching the SHELBY go together with its fate blowing in the wind just rubs me raw
« Reply #6 on: May 31, 2011, 11:10:56 PM »
Bet it bothers me more than it bothers you, BB  ;D  The car will get finished either way, though, whether I end up taking it to Drag Week or not.
cdmbill
« Reply #7 on: May 31, 2011, 11:14:12 PM »
The Futura has a better racing pedigree than many folks realize. A certain Ford pro stock driver form Whiteland, Indiana went undefeated in one of those back in the day and took the NHRA Pro Stock championship in the process.
Mario428
« Reply #8 on: June 01, 2011, 10:07:20 AM »
That happened just about the time my brother got interested in cars and we were keeping track of the Fords in Pro Stock.
Bob had 2 of them, 1 was retired undefeated in Pro Stock competition, the 78 I beleive.
All he wanted at the time was a Futura and 30 years later here we are.
« Reply #9 on: June 03, 2011, 12:46:34 PM »
Hi Jay---
Just a thought, but do you suppose a POLITE bombardment of calls/emails to the Hot Rod offices on behalf of your clone might get them off the dime? I'm sure a request for help both here and over at the FE Forum could well generate several hundred contacts.
