Author Topic: Just general FE info Bolts for a FE  (Read 5335 times)
FERoadster
« on: November 15, 2020, 10:11:37 PM »
Put this spreadsheet together to organize the bolts from my 20+ FE blocks from a scrap yard here in Brookings Or.
Some may find this helpful when you are looking through a pile of 5/16 or 3/8 bolts.
Posted this on the FEForum but others may see it here
Please provide me with corrections or additional info.
Intake bolts were checked  both with a C6 S intake and a Ford LR 2X4 intake.
Richard >>> FERoadster
Saw 2 errors Crank pulley bolts are not Fine thread. Oil PU to oil pump are 5/16, missed the cam bolt
« Last Edit: November 18, 2020, 12:12:01 PM by FERoadster »
winr1
Re: Just general FE info Bolts for a FE
« Reply #1 on: November 15, 2020, 11:32:27 PM »
Thanks Richard
Will help when I sort through my factory ford bolts as well as builds
Ricky.
« Reply #2 on: November 18, 2020, 03:11:08 AM »
A little more involved than just length. Take a look at the original timing cover bolts. They have nylon inserts in the threads.
FERoadster
« Reply #3 on: November 18, 2020, 12:11:29 PM »
I'll pull some out of a shortblock with a TC installed and see what I find.
None of the ones I have taken apart seem to have the nylon locking puck.
Was that a later year change?
I'll be updating the spreadsheet later today.
Richard
BigBlueIron
« Reply #4 on: November 18, 2020, 02:03:22 PM »
Aren't the oil pan bolts that go in the front cover longer? Or maybe that's just how I always put em back together. And I believe there are 2 different lengths of necked down rocker arm bolts.
yellercat
« Reply #5 on: November 18, 2020, 03:08:02 PM »
Currently looking for some of the bolts that connect the driveline to the C6 transmission.
They are 'special'.  :o
Brad
52' F-1
69' Camper Special
70' F-100
88' F-150
FERoadster
« Reply #6 on: November 18, 2020, 10:01:12 PM »
Thanks for the replies. I'll have to check  the oil pan bolts , but C6 trans bolts? drive shaft to flange on a 2 piece shaft? don't know if I have those bolts but do have flanged C6's and drive shafts that match. That's farther out than I wanted to go but I'll try to get those included.
Richard
yellercat
« Reply #7 on: November 19, 2020, 07:13:49 AM »
That's the ones Richard. They have a grooved surface on the smooth (non-threaded) part of the stem; apparently to reduce twisting with the torque I would guess. Looks like a wheel stud bolt that way. Haven't seen them available and not sure what others may have uses as an alternative. Farmer in me says to stick an 8 grade in there and run it. :-\
Brad
52' F-1
69' Camper Special
70' F-100
88' F-150
CV355
« Reply #8 on: November 27, 2020, 06:18:25 PM »
5/16"-24 x 1" on the water pump pulley, if you wanted to add one...
"Oh I'll just take a quick stroll to the hardware store for some pretty stainless hardware."  Nope.  Fine thread is a pain to find locally, unless you are ok with buying a box of 25 or 50 from Fastenal.
