Author Topic: Regulator Position After Carb - Why?  (Read 3883 times)
CV355
« on: October 02, 2020, 07:59:15 AM »
Can someone explain the methodology and logic behind putting a regulator AFTER the carb?  I just got in a Holley Super Sniper 1250 kit, and they are recommending putting a regulator after the carb.  Wouldn't that just allow the electric pump to supply full pressure to the fuel log and then only regulate the return line?  Pneumatics and hydraulics are my livelihood and this is making no sense to me...
https://documents.holley.com/199r11488r.pdf
Page 12
I have an Aeromotive bypass regulator that I planned on putting in-line BEFORE the carb (or EFI carb in this case, whatever).  Would that arrangement still work?
allrightmike
Re: Regulator Position After Carb - Why?
« Reply #1 on: October 02, 2020, 08:18:02 AM »
Apparently the regulator can flow a greater volume of fuel than the pump can and therefor is able to maintain the correct pressure in the system.
CV355
« Reply #2 on: October 02, 2020, 08:36:03 AM »
But, a differential flow would only normalize at the max flow rate.  If the carb or EFI system isn't flowing enough fuel, wouldn't the pressure spike?
I know I'm looking at this from a perspective from a different industry, but I figure the same principles apply - it's not like physics changes just because it's automotive haha
427stang
« Reply #3 on: October 02, 2020, 08:42:00 AM »
It is to maintain inlet pressure at all engine loads. Sequential/Bank-Batch fire Injection do the same. The regulator is basically a relief valve to bleed off excess pressure so the injectors see a consistent fuel inlet pressure.
CV355
« Reply #4 on: October 02, 2020, 08:46:27 AM »
That makes more sense- I was thinking of it in the reverse manner, where the post-regulator was trying to maintain or reduce pressure before the carb, which would never work with a traditional regulator.
SSdynosaur
« Reply #5 on: October 02, 2020, 10:39:36 AM »
Maybe not completely relevant but I can describe what my fuel pressure data graph indicates on a Super Stock drag car launch where the diaphragm/pintel style regulator is mounted before the carbs (both physically and hydraulically). Sitting on the starting line, engine WOT but rev limited to 6K, the recorded fuel pressure is exactly 5.5psi (reflects static setting without engine running) and the pressure graph is nearly linear. However, the instant I drop the clutch the pressure plot indicates a high frequency oscillation (saw-tooth graph) between 8 and 4psi. As initial forces of gravity diminish from the launch the pressure oscillation-frequency drops continually with the plot indicating a near linear characteristic by around the ⅛ mile (half track) through the end of the run. There are a ton of forces and counter-forces interplaying here but, basically, what the plot indicates is the the limits of the regulator's ability to control the dynamic fuel pressure under this specific set of conditions. There is certainly an optimal regulator discharge orifice size (a compromise) that permits an acceptable pressure control range combined with acceptable volume delivery but mechanically, as it does it's job it introduces these wild pressure oscillations. Apparently, we can make sufficient modifications the the carb delivery system to make it all work. I'm definitely not a FI person but my best guess is that placing the regulator post-throttle body would smooth the observed saw-tooth oscillations effects on the throttle body.
RJP
« Reply #6 on: October 02, 2020, 10:58:24 AM »
I use a B/G bypass regulator on a twin turbo, intercooled draw thru system using a single 850 Holley C/S so that the volume of fuel is not restricted by the pintle/orface as it would be if the regulator were between the pump and the carb. It is plumbed in reverse from a dead head regulated system. IOW Fuel comes from the carb's fuel log into the "out" port of the regulator and the discharge [fuel return] uses the "in" port and is plumbed back to the tank. Only advise I can offer with this type of setup is make sure the fuel lines are big enough to handle the volume and pose no restrictions at all.
CV355
« Reply #7 on: October 02, 2020, 11:59:28 AM »
This is excellent info.  Concise, technical, I love it.
I think I understand it now...  So you are using it as a flow-control instead of a true regulator.  I need to run this by my pneumatics guru- this will blow his mind for sure.
« Last Edit: October 02, 2020, 12:20:53 PM by CV355 »
« Reply #8 on: October 05, 2020, 10:40:51 AM »
My .02 from the little bit of FI I have dealt with.  Remember that Sniper only "looks" like a carb, but functions as FI.
FI can NOT have any fluctuation in pressure or the engine will lean/richen as it moves around.  It must have a very large, unrestricted amount of fuel at the injectors, unlike a carb that just draws fuel using vacuum from the fuel bowls.  A carb fuel system can see some pressure swing and not stumble like a FI system(as long as the bowls are full).
The injectors in that "carb" body need to see a very specific pressure ALL THE TIME.  That is why the pump in the tank is a high pressure unit.
« Reply #9 on: October 05, 2020, 11:02:20 AM »
Almost every EFI system I put together regulates after injectors.
The pressure the injectors see, whether it is rail or TB, will never be higher than the regulator controls
Think of the regulator of a dam with spillway, having the fuel held back for the injectors at a certain pressure, anything above that set pressure goes back to the tank
« Reply #10 on: October 05, 2020, 09:32:50 PM »
That's very well said.
« Reply #11 on: October 08, 2020, 08:48:01 AM »
Putting the reg after the carb allows the pump to use it's full volume capacity to feed the carb(s).  Technically, you could be reading 1 lb of fuel pressure but the pump would be feeding max capacity and the engine consuming nearly all of it.  In practice, sure you don't want to get to that level of draw.  Same as noted with FI - the mechanical systems use a pill to pass unneeded fuel back to the tank, same with a return regulator.  SIde benefit is that the pump runs cooler because it has fuel flowing through it rather than banging against a stop (dead head regulator).  Also reduces surging in the carb feed and foaming in the fuel bowls.
CV355
« Reply #12 on: October 12, 2020, 12:31:31 PM »
All good info in this thread.  I appreciate it, guys!
DubyaTF
« Reply #13 on: October 14, 2020, 10:22:16 AM »
   Diesels are most commonly setup with regulator on the return. This provides the maximum amount of fuel for lubrication, cooling and burn. It should also cut down on the amount of introduced bubbles into the flow for a more steady a/f mixture. Our Army's combat equipment uses a small clacker style pump (sometimes dual pumps) to feed the high pressure pump which feeds the injectors that, in a Cat 3126 or bigger, fires at 3500psi. Where you measure fuel pressure is just as important as where your regulator is I would say. Keeping tabs on inlet AND outlet pressure may be a good idea.
Jeff
BigBlueIron
« Reply #14 on: October 14, 2020, 11:16:02 AM »
To add, most older mechanical diesel injection pumps use a fixed orifice on the fuel return to control internal pump pressure. The pump body itself acts as a fuel rail.
RustyCrankshaft
« Reply #15 on: October 15, 2020, 08:27:48 PM »
3126 uses a "HEUI" injector that fires the injector based on ECM input and uses oil pressure to actually make injector start (on a C7 the injection event is commanded on and off, 3126 is more like a PowerStroke or Navistar injector where the injection event is stopped by return spring pressure on the oil side), not fuel pressure. A 3126/C7 should run a consistent fuel pressure and also uses a regulator on the return on most applications. The ECM will change HEUI pressure based on temp, load, RPM, etc. etc. However, a 3126/C7 will run anywhere from about 650psi to 5000psi of engine oil pressure and still fire the injector.
a 3116 Cat uses a mechanical unit injector that is VERY much like an old skool 2 stroke Detroit injector. In this case the injection starts based on cam timing and what pressure the nozzle valve opens at depends on
This is slightly different than in a pump and nozzle diesel injection system. In this case, the nozzle only cares about what pressure it sees from the distributor head on the pump and when the pressure rise over comes nozzle spring pressure (commonly called the pop pressure in the fuel shop)
Eletronic unit injectors or high pressure common rail stuff is sort of a combo of both of the above.
Also on a lot of diesel's, the fixed orifice on the return side does a couple things. In a mechanical pump is may be the pressure regulator to control supply pressure. In a lot of newer stuff (last 25 years or so) that orifice is used for erosion control due to the ever increasing pressures.
A regulated return helps maintain consistent fuel temperature and helps keep aeration down (this is more so a problem with diesel and derivates). A dead end system tends to heat soak the fuel, although in new production cars composites and better heat management have helped mitigate the problem. If you have a small fuel cell and want to do a lot of street miles I've run a regulated return with a cooler on the return to keep from boiling the gas. Works with carbs, although you can't do much if it's the fuel bowls themselves that are getting heat soaked.
DubyaTF
« Reply #16 on: October 16, 2020, 02:49:36 PM »
  Yup- preaching to the choir on the HEUI system. I was trying to draw the correlation of regulating before or after the pump in those systems without getting into the weeds too much. That's why I didn't bring up rotary pump systems.
  Good point about smaller fuel cells with dead-headed pump though. I've always wondered why a fuel cell didn't incorporate a cooler on some model of cell. I would think road course or circle track cars would benefit as long as the rules permit it.
Jeff
RustyCrankshaft
« Reply #17 on: October 16, 2020, 05:14:11 PM »
I actually don't mind the HEUI stuff, but it does require some special attention unless you want to work on it all the time. I've probably done thousands of C9 injector cups and injectors at this point!
I don't do much racing anymore, but I've had a couple street cars that I built that could also do double duty on road course track days and ran fuel coolers on the last 2 and it really helped on the carb'd ones. Along with a plastic spacer I never had any trouble with vapor lock or fuel boiling. They all ran some sort of regulated return, but without the cooler I'd still get hot fuel bowl syndrome if it was hot and I got stuck in traffic or a long wait in the healthfood driveup window.
