Author Topic: Would someone tell me what piston I have here is?  (Read 3684 times)
FERoadster
« on: September 18, 2020, 01:44:59 AM »
Asked on the 332-428 FEForum and no reply.
It's in an EDC block that seems to be cast in 1958. It's a rebuilder block I bought about 25 years ago and just stored it,
Pistons are L2116 and are +030. Bore measures at the top (no ridge) 4.015 and the piston at the top 3.985. Seems to be too small a bore for a 352 but did 332's  have  a smaller bore? Crank  measures a 3.50 stroke, So is this a 332 block with a 352 crank? Piston is barely below the deck.
Richard >>> FERoadster
wowens
Re: Would someone tell me what piston I have here is?
« Reply #1 on: September 18, 2020, 05:13:25 AM »
Off this website
Displacement Bore Stroke
332 4.000 in (101.6 mm) 3.300 in (83.8 mm)
352 4.002 in (101.7 mm) 3.500 in (88.9 mm)
360 4.052 in (102.9 mm) 3.500 in (88.9 mm)
361 4.047 in (102.8 mm) 3.500 in (88.9 mm)
Woody
chris_r
« Reply #2 on: September 18, 2020, 11:03:30 AM »
You measured wrong place......Measure the piston 90 degrees from the pin
« Reply #3 on: September 18, 2020, 12:06:55 PM »
The only FE, that I know of, that has a smaller bore than 4", is the 330 truck engine @ 3.875.
The 4.015 bore diameter with a piston that is marked .030, is very different and I think the only thing that you can do now, is pull a piston and confirm the measurements and any casting numbers that the piston might have.
I believe the 78 marking, is a hold over from the early Ford era. The 1946 heads, were marked 59A. The 5 being the design date.
I was looking on Ebay for FE pistons, last night for a '58, 361 engine that I will get soon and found a set of NOS, Sterlings brand pistons for a 332, with no valve reliefs. They looked a lot like yours but, the front marking was the usual notch. The part # was 216P.
Added:
https://www.ebay.com/itm/1958-1959-Ford-Mercury-Edsel-FE-332-NOS-Sterling-030-Piston-Set/143519747149?hash=item216a718c4d:g:1K4AAOSw1OBeCqry
« Last Edit: September 18, 2020, 12:18:37 PM by frnkeore »
