Author Topic: What material to use for building a main girdle?  (Read 8394 times)
Royce
Re: What material to use for building a main girdle?
« Reply #15 on: September 09, 2020, 04:33:43 PM »
Sounds like the infamous Shoe cap saddle would be what Joel is looking for.
. I did something slightly different than JDC's setup. I had taller steel caps machined so they are level with the pan rail  then a girdle lays on top  pinned in place and bolted down with studs through the whole assembly/  A lot simpler to machine..  You think that 392 needs more bottom end beef?
1961 Starliner 390/375 clone
1965 GT40 tribute w/FE
1992 BMW V-12 5.0
2001 Lincoln 5.4 4 cam
2000 Jaguar XK8 (Ford V8)
