Author Topic: Guess the horsepower game on Project Junky Junk.....  (Read 27499 times)
Re: Guess the horsepower game on Project Junky Junk.....
« Reply #30 on: September 26, 2020, 02:44:36 PM »
Should be a nice little setup.
429 HP and 476 ft lbs torque
70bosscat
« Reply #31 on: September 26, 2020, 07:31:59 PM »
460hp and 427tq
Pump gas compression, factory heads and a cam that will want to spin makes you go hmmm.
« Reply #32 on: September 27, 2020, 05:29:08 AM »
460hp and 427tq
Gotta start somewhere.  The next iteration will be a lot more fun.
« Reply #33 on: September 27, 2020, 09:32:19 AM »
I think the other thing to remember is we are talking healthy 427 power out of a 352 without any significant head work and a dual plane intake.....
May not sound like big power, but even 425 HP is 1.20 per cid, that'd be a 512 HP 427 or a 578 HP 482, of course the heads wouldn't feed the big guns, but this little 352 is nothing to sneeze at.
Stuck in a 67 Mustang with a 4.30 gear, it'll be a hot machine, can't wait to hear the results and see it grow from there
« Reply #34 on: September 27, 2020, 10:49:39 AM »
If the heads flow in the 240-250 cfm range, and with over .600" lift solid roller camshaft, and ported intake, with the 10.5:1 compression, the good ring package, etc., should be in the 1.4-1.42 hp/ci range.  My little 303Y with similar preparation, head flow, .600" lift solid lifter engine made 390tq/463hp with 10.45:1 compression.  No reason the 352 can't do the same.  JMO, but it should be a good chance to see what a blueprint can do with a forgotten engine.  Joe-JDC
DubyaTF
« Reply #35 on: September 29, 2020, 02:53:02 PM »
  492 hp with 450 lb/ft
Jeff
« Reply #36 on: October 08, 2020, 08:26:26 AM »
Cometic says they won't ship head gaskets until 10.20.20.   I've been waiting since I placed the order on September 8.
I canceled that order and will just use a set of 1020's.  I'm going to lose about .2 of a point of compression because the gasket bore sizes are so dissimilar, but I'd like to get this thing dyno'd before 2021.
bluef100fe
« Reply #37 on: October 10, 2020, 08:02:55 PM »
I’ll guess... 460hp and 410tq... I think the cam duration is gonna hurt the tq some, along with the low compression. Narrow LSA should help some with that but I’m thinking this thing will run like a old 2 stroke dirt bike... kinda dead down low and then come on strong in the mid range and rpm for days up top. Neat build Brent.
Cody Ladowski
1976 F-100 stepside
390 C6 9 inch
1.56 sixty ft.
7.38 @ 91.5
11.79 @ 111.5
« Reply #38 on: October 16, 2020, 04:52:55 AM »
Well, head gaskets are here and heads are on.   Measured for pushrods but Trend wasn't able to ship a full custom set until the 23rd, so I ordered through Smith Brothers.  I'd like to have this engine together before I turn 85.
« Reply #39 on: October 16, 2020, 12:35:01 PM »
Could be worse Brent it could be a customers engine. Your still young 85 is a long way away. :)
« Reply #40 on: October 29, 2020, 06:06:21 PM »
Alright, engine is done.  It just has to wait its turn to be dyno'd.  I hope it will be 2 weeks tops.   Going to the dyno tomorrow, but it's customer stuff first.
Waiting its turn....
« Last Edit: October 30, 2020, 05:18:08 AM by blykins »
wayne
« Reply #41 on: October 30, 2020, 08:35:28 AM »
The old 3 bbl will make a good show if its not to big
HarleyJack17
« Reply #42 on: October 30, 2020, 10:55:49 AM »
3 Barrel....I may need to up my numbers just a tad....they can surprise you.
« Reply #43 on: October 31, 2020, 09:08:04 AM »
Dyno'ing on the 13th.  Finally.
Almost a year to the day from when I put it on the dyno when I first got it.
« Reply #44 on: October 31, 2020, 09:24:58 AM »
You do realize that's a FRIDAY the 13th? You sure you want to do that?  ;D
