Author Topic: Update ...Filter size or filter area required for cubic inch  (Read 3004 times)
winr1
« on: September 02, 2020, 11:57:25 PM »
Is there a formula for filter area for cubic inches ??
Took the insides out of my 65 F100 oil bath filter, nothing worked to keep oil from getting on intake
This filter will fit without crowding the air coming in, may include some holes or slots as well
Filter  paper.. Wix
3.910 tall
9.390 OD
6.660 ID
2.73 thick
Ricky
« Last Edit: September 04, 2020, 09:58:04 PM by winr1 »
Re: Filter size or filter area required for cubic inch
« Reply #1 on: September 03, 2020, 07:58:39 AM »
 A = (C.I.D. x RPM) / 25,500 -   So requirement for a 390 at 5000 RPM = 76 square inches
To find filter area, it's a little more difficult, but good thing is a paper filter should have more area with pleats than the math will show, and there is a lot of fudging here and there with height too
Area = Circumference (likely greater in a paper filter X  Height (likely less in a paper filter due to rubber ends)
C= 2piR or pi X diameter
For your filter, that comes out to 115, so you have more than the minimum for the engine I put at the top
(Pi X 9.39) X 3.91 = 115 square inches
There is a ton of wrong in that calculation though, LOL, the OD measured OD of the filter will be less than the rubber, the measured circumference of the paper will by MUCH larger due to the pleats, and the height of the filter is likely not the height of the media
Here is a calculator, no idea if it's right, but slightly more detail than a pure area comparison with lots of fudged figures :) and it came up pretty more conservative but still good
https://www.secondstrike.com/Technical/AirCleanerCalc.asp
« Reply #2 on: September 03, 2020, 12:29:29 PM »
Not sure how you intend to put that paper element inside the oil bath but don't do it like the guy who came over to look at my oil bath air cleaner. He bought the truck like that and brough his oil bath over. There was a paper element inside and the sheetmetal baffles were cut away. But no inner lid or nothing on top of the element so air is free to just run in the snorkle and overtop the element.  Kind of like having a 6 foot chain link fence around your yard to keep birds out.
« Reply #3 on: September 03, 2020, 10:48:00 PM »
Tom---
It might work for eagles if you could keep them a a 4-foot height!
« Reply #4 on: September 04, 2020, 08:53:01 AM »
No.  My door car runs the same with a 14x3 element or the single 5x3 in the Hilborn style scoop.
winr1
« Reply #5 on: September 04, 2020, 09:56:55 PM »
Thanks guys  :)
Not sure if the lid will look odd with the 3.910 tallfilter
oysters hampstead nc
Not much room for air to enter
Thought I might trim the lower piece edge lower and leave a slight lip
Found another filter .. 3.545 tall....  9.718 OD ...  8.187 ID ...  1.523 thick
The lid fits lower ( of course.. )
Going to cut out a round setion of something to seal the top of the filter
Have seen various filter bodys where some have cut slots and or holes to allow more area
Had a 4 barrel oval filter on the truck before and it was loud cruising, even more so when acceleration
Ricky.
