FE Technical Forum
Fe mill with C4 trans .... JPT bell or COM bell
Topic: Fe mill with C4 trans .... JPT bell or COM bell (Read 3526 times)
winr1
July 19, 2020, 10:12:16 PM »
Any run a C4 with a JPT bell or a modified COM bell ??
Curious as to what converter would be used
My JPT bell was modified to fit an 184 tooth FE flywheel
What flywheel would one run in a JPT bell if it was not modified ??
Does the converter need to be FE on the crank side and C4 on the trans/pump side ??
Ricky.
Jim Kramer
Jr. Member
Re: Fe mill with C4 trans .... JPT bell or COM bell
Reply #1 on:
July 20, 2020, 12:19:32 AM »
Ricky.. I used the C6 converter with my modified COM bellhousing. The C4 stator support is the same as a C6, And you can buy an adapter bushing to make the C4 input shaft work in the C6 converter. The COM bellhousing is .850 deeper than the C4 bell so the converter needs to be spaced back a like amount with fabricated spacers. Sounds kind of jury-rigged but I put hundreds of mid to low 1.40 sixty foot runs on mine with zero problems. If you need a decent 4500+ stall racing converter I have a couple......Jim Kramer
JamesonRacing
Sr. Member
1966 - What a great year for FOMOCO
Reply #2 on:
July 20, 2020, 05:57:52 AM »
I have a JPT bell on my C4 and the standard 184T flexplate and C6 converter (with spline adapter) fit fine.
Reply #3 on:
July 20, 2020, 10:09:07 AM »
The spline adaptor works if you want to use a C6 converter , they even have a spline adapter for a C6 converter in a AOD too
winr1
Reply #4 on:
July 20, 2020, 05:07:12 PM »
Thanks guys !!
My JPT bell has been built up with weld on the bottom
The bottom and top have been milled, a 184 tooth flywheel barely fits
Will take a pic and post, curious as to why the modifications
Ricky.
FE Technical Forum
