Author Topic: How strong or good are the Eagle Rods for $350  (Read 10866 times)
gt350hr
Re: How strong or good are the Eagle Rods for $350
« Reply #15 on: July 17, 2020, 04:09:38 PM »
   Yes Dennis is still in business and buys the rods / cranks from RPM.
 Probe/Vigilante does the same thing. The fully machined I beam is a nice rod and you might be surprised who else sells them under their own name.
allrightmike
« Reply #16 on: July 17, 2020, 05:43:12 PM »
I have had good results from Eagle rods, having said that I have an interesting story more to do with the ARP rod bolts than the rods. Using a stretch gage and torque wrench to tighten the rod bolts I found one soft bolt (up to stretch WAY before torque range. Called ARP, they said this is a proprietary bolt for Eagle (this was an upgraded bolt). Called Eagle, they didn't really care but would sell me a new bolt for $12.00. Didn't tell me it would cost almost $30.00 to ship it! Just saying.
'60 Starliner 427 4speed.
« Reply #17 on: July 17, 2020, 05:49:02 PM »
I've used one Eagle product in all my years of building engines.  Used a steel 4.100" crank for a Windsor about 17 years ago.  Didn't have any issues.
A few years after that, I ordered two 4.150" BBF Eagle cranks and both of them had dings and pits in the journals, so I sent them back and bought Scat.
A few years after that, there were 3-4 guys on Club Cobra who were scattering engines.  All of them were Eagle cast cranks.  All of them broke at the 1/5 rod journal.
I think some guys use them and have luck with them but I've had a bad taste in my mouth about them for quite a few years.
Posi67
« Reply #18 on: July 18, 2020, 12:48:47 AM »
Kinda what Brent said. I have a SBF buddy that makes a lot of HP without a problem using Eagle rods. I also know of some FE and 385 Ford guys that had both rod and crank breakage with Eagle. The 428 currently in my car has Eagle rods that have been beat o for years so who knows.
Personally, I'd never buy Eagle anything since there are other choices out there now. I can't imagine you'd get any kind of quality rod for $350.00 though. Spend your money and take your chances comes to mind.
KMcCullah
« Reply #19 on: July 18, 2020, 09:43:46 AM »
I don't know if Eagle is offering several levels of FE rods these days. But $350 seems pretty cheap. I'd pop for the upgraded rod bolts if available.
Ten years ago I bought a set of Eagle H beams for $450ish. They had some nice bolts with 12pt nuts. And the bores measured pretty good too. I remember being surprised because they were considered oriental trash. I used them in a 390 with a set of beat up TRW 12:1 pop-ups. I beat on that motor for several years mud racing. Spun it up to 8K numerous times. Finally gave the 390 to dad for his hot rod F-100. He put a scatter proof bell and a T10 behind it and continues to punish it weekly. No problemo with this particular set of Eagle rods.
Kevin McCullah
pbf777
« Reply #20 on: July 18, 2020, 11:15:19 AM »
     O.K., here's another opinion, and you know everyone has one, but with exposure to many examples from many different manufactures, the bottom line is that in the world of quality aftermarket racing connecting rods in the marketplace the China stuff, and yes there are different grades of it, is all pretty low on the totem pole from the standpoint of durability & survivability, but may prove sufficient,  ......................sometimes.           :-\
     Noted issues in comparison to units one would spend more money on:
               Dimensional sizing not as accurate, be sure to inspect all dimensions (as one was going to do in any event), as often requiring resizing of big ends is required, pin-fitting (which is O.K.), big-end & small-end not in alignment, lengths & widths off "some", etc., all as in "came-out-of-the-box" condition.
               Grudgeon pin bushings are softer causing greater wear rates or in somewhat more extreme situations just get displaced more readily from the load.
               Rod body steel material generally is less rigid, bends, bows, pin-end elongates easier, big-end doesn't hold round as well. And as for the big-end, the problem with the "up-graded" bolt package is that often the increased clamping force surpasses the strength of the rods' bolt post causing issue with reasonable repeatability in sizing upon torquings.            :o
     Remember, it is true, you get what you pay for; but still, yes, often better than the O.E. as was not intended for racing stuff, so perhaps "sufficient"..............sometimes.          ;)
      Scott.
1967FEGT
« Reply #21 on: July 24, 2020, 04:38:07 PM »
Dennis at DSC is who I supplied my rods. I assumed they were Eagle rods. They came with the more expensive ARP bolts. I also had them magged and checked for size. They required no resizing and balanced without issue.
The pessimist sees difficulty in every opportunity. The optimist sees the opportunity in every difficulty.
