Author Topic: setting valves on solid cam for dummies  (Read 2946 times)
62Falcon390
« on: June 20, 2020, 03:48:58 PM »
i got some new crane adjusters to replace the stock adjusters, and need a dummy look at how to adjust them.. Ive tackled it before and had poor luck. BUT not to give up,, I need to change out the wore out adjusters and have another crack at it., cam calls for .018 valve adjustment, so would really appreciate a idiot proof way to set it up.
thanx
RIck
62Falcon390
Re: setting valves on solid cam for dummies
« Reply #1 on: June 20, 2020, 04:25:23 PM »
EOIC.. finally clicked.. all good
Rick
« Reply #2 on: June 20, 2020, 04:33:15 PM »
If you have aluminum heads, set the lash .006" tighter when it's cold.
62Falcon390
« Reply #3 on: June 20, 2020, 04:35:35 PM »
iron heads, thanx
